10 ply tire houl
Woodblocker55
I had these pretty aggressive four-wheel drive style 10 ply truck tires on for about 1 year . Never rotated yet. Can those tires houl worse as they wear .. ?? There really talking on tar now lol ...
Sent from my LGL722DL using Tapatalk
Yep, they howl louder and louder as they age, some worse than others.
Woodblocker55
Woodblocker55
Thanks .. Ya I will rotate them there letting me know its time lol . There not the cheapest but not most expensive either. There in the middle ..but I got little to aggressive ones maybe ..[emoji849][emoji15]
Cbncanada
I rotate mine every 10,000 Km. They last much longer that way and wear more evenly.
Woodblocker55
Woodblocker55
Ok will do I'm at 10,000 miles might start rotating sooner like you say 5000-6000 miles . [emoji41][emoji106] Thanks
Cbncanada
I chose 10,000 km as it worked out to every second oil change. You can choose your own mileage.
Teamiez
Make sure they are properly inflated if they are a LT E tire as well.
Woodblocker55
Woodblocker55
They are LT and there E weight .. I got 40 psi when not pulling anything . I just guessed that be right so it slow down the rough ride .
Yukon xl like 5700 lbs .
Teamiez
I am on my third set of bfg ko series, my last set I ran at 38-40 and only got 37,000 miles with proper rotations. Just got the new set and according to BFG they recommend 48 psi. I thought I would hate the increase but turns out the truck drives better then ever ! Just figured I’d toss it out there as I just learned myself.
exp500
Howling is usually an alignment issue- generally too much toe in. Look at the sidewall of tire, inflate to max pressure shown as a starting point. On a 10 ply you can drop 10# or maybe more if tire crown excessive. I run Cooper AT3 and love em. About 50-60000 per set at 60#.
greygranny
