Runs like crap after plug change
I changed to AC Delco and the problem immediately went away. Do check out the Delco plugs closely as I had a bad one new in the box that was cracked
Just a friendly FYI on replying to posts here on the forum. Either you’re hitting the quote button and then quoting posts without replying or hitting the reply button without replying but all you need to do to reply is hit reply and then type in your message and then hit post. Otherwise you end up repeating what others say with no explanation why and end up with multiple posts like just happened.
