Need help deciding on level and tires
phaley99
I just purchased a 2011 Z71 Tahoe that’s totally stock. I’m wanting to level it and throw some tires on but have no idea what fits and which level to buy. From what I’ve read I can maybe do a 2” level and 285/70r18 tires.
I’m really wondering about a 2” vs a 3” level and different size tires that I could fit with each.
any and all help is appreciated
Welcome Patrick! You can get the Rough Country 2" spacers that go under the shocks to take care of that and should be able to run those tires on your stock wheels without trimming. Pete @Galante has near the same setup with 17 inch wheels on his 2013 Tahoe.
Take any photos of it yet?
2010gmcyukon
Midwest
Welcome to the Forum from NH.
Pics, please.
Regarding your questions, I offer the following:
What is your total budget for lifting/leveling parts, wheels, and tires? Having a firm budget will make the rest of the decisions and associated trade-offs easier.
What is your intended use of this truck, and what surface do you do most of your driving on? This will help determine the best and most cost effective tire selection for you to consider, unless the 'look' of the wheel/tire combination is your major objective.
Regarding wheel/tire combinations that will fit your truck without rubbing, no 2 trucks and their suspensions are exactly alike, due to a number of factors including accumulated wear on the suspension components, so there is no guarantee that what fits with no rubbing on one truck will automatically fit with no rubbing on your truck. Other folks experiences can guide you in one direction or another, but the final test will be when you mount the wheel/tire combination on your own truck.
To assist you in getting a good idea on whether or not specific alternate wheel/tire combinations 'may' fit your truck with no rubbing, I recommend that you use the wheel/tire comparison app at the URL listed below. You can use this app starting with your existing wheel/tire combination as a benchmark, assuming that there are currently no rubbing issues with it, and measure the actual critical fender and suspension component clearances as directed by this app. Then, you can enter alternate wheel/tire combinations, and this app will give you the projected changes in these critical fender and suspension component clearances.
https://www.wheel-size.com/calc/
I used this app for determining whether on not I could use my current alternate wheel/tire combination, and it accurately projected the changes in critical clearances. Again, the use of this app in not an absolute guarantee that an alternate wheel/tire combination will fit without rubbing, but it provides a much better assessment, or projection, than simply an educated guess on your part, or a statement from others that it worked on a truck other than yours.
09_4WD_YUKON
Do you need longer shocks or shock extenders with this kit? How is your ride quality?
No, I just put the kit in. rides just as good as before.
@09_4WD_YUKON I have a question about the spring insulators, when you installed your rear spacer did you use 3 insulators or did you just use 2?
Honestly, I really don't remember.
phaley99
phaley99
Thanks for all the feedback and help. Unfortunately my truck was flooded during hurricane sally as I live on the gulf coast. I had the truck for a grand total of 5 days.
I think I found another z71 one though so if I purchase it I’ll probably go with the 2in and 285/70 KO2s.
Tman406
09_4WD_YUKON
I'd pass on the nittos if you live near ice. I have them on my 4runner and I'm not a fan of their performance on ice. Just my.02. Heard other things from other folks though.
I ended up going with Mickey Thompson Baja MTZs. 4 Wheel parts had a killer deal on them, buy 3, get 1 free with free installation. 4 tires mounted and balanced with their protection plan for $1,061. 285/70/17
justinakay79
