Getting ready for lift and tires
Shumif1
Ok , everything is on order . Leveling kit ,20" wheels and 275/65/20 tires. Will post pics when it's done. One question , how do I calibrate the speedo afterwards ?
GreyStone
with a tuner
BlackBearPerf
Supporting Member Supporting Vendor
Coeur d' Alene, Idaho
We would be more than happy to help, with the speedo calibration and much more with a custom tune. If you would like give us a call 877-809-4070 or email [email protected] for more info.
x3.
Get the Black Bear Performance tune for the ECM and TCM, and you WON'T be disappointed. You will get the speedo adjustment as a free side benefit. And, with a Black Bear Performance tune, you will be able to get future free tune adjustments from them, any time that you add a mod that could impact performance.
S
Shumif1
x3.
I'll look into it thanks.
massivespl
I'm not mean, I'm honest.
Michigan
Your speedo will be off like 2-3mph after 55mph... just use a gps one time and remember how far off it is. No need to spend money on getting it recalibrated if u ask me.
S
Shumif1
OMG ,WHAT A NIGHTMARE:flame: , The leveling kit went in no problem but the tires are turning out to be a nightmare. After everything I read and asked the 275/65/20 don't fit , so I went to a 265/60/20 and STILL RUB.
GreyStone
stock rims??
HiHoeSilver
Away!
Chicago
What's the offset on the wheels? Pics? I'm surprised you're rubbing. That's not even a 33" tire. I'm running 275/70/18 (33.2") with just a few turns on the stock keys.
Something's not right. What are your fender heights?
S
Shumif1
offset is 31. Here are pics of before and after. I heated the fender liners with a heat gun
and it's not rubbing anymore. With a leveling kit .
offset is 31. Here are pics of before and after. I heated the fender liners with a heat gun View attachment 256822 View attachment 256823 and it's not rubbing anymore. With a leveling kit .
Could the troubles have been because of the Z71 flares? Or the extra half inch width of the wheel with the stock offset? The 20 inch wheels used on the 900s are 8.5" wide.
S
Shumif1
The flares were not in the way but you are correct about the 9 inch wheels . I think if I went with 265 instead of 275 I would of been ok .
Dustin Jackson
@Shumif1 The black accents compliment the color of that Tahoe exceptionally well. Looks great man. I am running 1.75 inch wheel spacers on factory 20inch wheels and about 3.5 inches of lift and I rub like crazy. I don't think there is anyway to fix it until I get different wheels.
AdrienR
