Temp gauge not going up/overcooling
Elon Powell
Mississippi
on my 1999 escalade (5.7) i drove it hard for 10 minutes and the gauge will only get up to about 160 maybe it is overcooling or a bad gauge please help
96-2D-Hoe
My 96, with a newish coolant temp sensor shows 160 on the gauge, but the engine coolant temp is 195. You need an OBDII tool to check ECT. The bluetooth gizmos that cost around $20 will give you this and more.
wjburken
Eastern Iowa
Is this a new thing? Have you done anything work on our Escalade lately?
As @96-2D-Hoe said, getting a scan tool will give you a better idea of what’s going on.
Elon Powell
Elon Powell
Mississippi
it is a new thing it used to run at about 190 i will probably scan it and see if that will tell me somthing thanks for the help
96-2D-Hoe
Maybe your thermostat has stuck open. For the couple $'s it costs I would just change it, and the rad cap too.
Any OBDII capable scan tool will give you the engine coolant temperature
Elon Powell
Elon Powell
Mississippi
ok the thermostat is fairly new will probably scan it and then go from there
96-2D-Hoe
Sh*t happens. Don't rule that out.
Otherwise it's going to be an electrical / ground issue so you could check battery/cables etc.
PS.
The coolant temp gauge sensor is on the drivers side of the block toward the front middle and has a single cable that runs up to a connector over the top of the engine
Off Road Pedia
