Left rear window hits bottom with a thump
PatDTN
I'm guessing I've lost some kind of rubber bumper in the window track. Is this something folks here deal with? Is there an easy fix? The same door has a switch issue where the window switch won't go up but it works fine from the driver panel. Searching shows maybe I can just take the switch apart and clean it well.
Tinlizard
PatDTN
PatDTN
Is that a bump or did you mean to say something?
Tinlizard
That thump was a broken regulator for me. Take off your door panel and check it out.
PatDTN
PatDTN
Thanks. I've had my hands full with my blown engine so I haven't looked at this. I know my window switch on the same window only works down and I have to put it up from the driver's panel so I'll knock out both issues when I look.
Towmaster
