NEED HELP PLEASE! Power Seat - Driver's side not working.
TronPlayer
View attachment 255088 The drivers side powered seat is not working on my 2005 Tahoe. By not working I mean no movement for either the direction switch or the lumbar switch. However, the memory mode selection switch 1 - 2 does work and the seat changes position between the two. Also, the heater works. The passenger seat works fine. I've already replaced the switch, checked the fuses, and cleaned the contacts on the control module under the seat. What could it be?
S33k3r
Dallas, Texas
Might be a bad switch, or the wiring to those switches is bad. Just guessing though. At the very least, you should probably eyeball it.
T
TronPlayer
I've made some progress. The image attached shows that if I run a jumper between these to points the seat works. The main harness orange wire carries 12.4 volts, but the orange wire voltage is only 11.5 at the switch. Any insight on what the problem may be?
exp500
You are halfway there. Keep going in that direction, but quit jumpering power before you find problem. You already knew motor works. Test each pin in each switch position. Then test pins when memory reset. You are trying to decide if its the switch or BCM not allowing seat to move. Figure it out. I doubt both have failed.
Drewphil
