New pads and rotors, rear brakes grinding now
The pads are the same for the inside and outside so all I can think of is if you put them inside out as in metal to metal but I’m not sure if that’s even possible.
@swathdiver I was just doing some research on that parking brake shoe system, I had no idea that's how it worked. That being said I am not sure this is the cause of my problem, I have good sized streaks on my read rotors so it had something to do with the way the pads are seating on the rotors. Both rear rotors have streaks, maybe I put the rads in the wrong side? Is there a good diagram to show which pads goes where?
The squeeler goes on the inside. Did you grease the slides and the guide pins?
bladenbullet
how in gods name could you replace the rotors and not see the parking brake assemblies you installed the new ones over?...
chazbeaux
