CountMinsi
Pocono Mtns, PA
I replaced a totally rotted out exhaust hanger and adjusted my hood bump stops to get rid of some hood flutter. Sometimes it’s the little things that make you happy!
xLbYzXNCjPgUmsVz8
I also tried to quiet down the steering clunk with a hose clamp tightened above the plastic bearing (still original). It doesn’t seem to have done anything. I might give it another turn or two.
I’m still chasing an intermittent long crank after driving then parking for a bit. Already did fuel pump, MAF, and tune up.
CountMinsi
Pocono Mtns, PA
Have you tested the crankshaft sensor? Sometimes that cases long cranks.
Not yet. Any guidance on how to test it? I’ve replaced the starter, so I know how to get to it. Thanks.
It might be a bit before I get to going after it. Been “traveling” full time with my family in our RV. By traveling I mean set up in a campground after selling our house in March to travel but having the plan interrupted for obvious reasons!
Economy install, lol I think I have spent about $700 for parts, used door speakers rear 6.5" kickers were $60, front nakamichi components $80, new alpine head unit $300, used sub amp $60, then amp kit and pac adapter and swc adapter not sure if I have the right one but I'll find out, backup cam off Amazon, justpieced it all together, getting that dam 0 gauge thru the firewall grommet was the hardest part, once I got it thru I sprayed it with wd40 and she went like greased lightening
Gotta have tunes.
Phlipnstik
