Show off your 2015+ leveled Tahoes and Yukons!
nglauer
Thanks brother. Just popped the front wheels off. Went with the suspension max for the mag ride since they're still going strong.
Hoping to get 1.75" up front tonight if possible, then I can get the atturos on and aligned.
Running the 5100s in my Tahoe and they're firmer than I'd like. Haven't tried them on a coilover yet. You like em compared to mag-ride? I like the how mag ride handles on this XL
Trimmed the front air dam over lunch freehand. Liking the extra clearance a lot
What did you use to cut it? I see a Dremel.. but curious what what wheel you used. I assume that is a sanding drum on there in the photo. Just curious if the cut off disks will gum up...
Sent from my SM-N975U using Tapatalk
BeenChevy
Minnesota
Used your standard 426 reinforced disc. Didn't gum up bad but went with the heavily used already disc. I cut right on the notch of the dam almost like it was the intended cut here. She just glided right through er. Pulled off any melted chunks and then smoothed across a few passes with the grinding bit and a little sand paper. A wide file would've worked well too
nglauer
I'm hoping I have time to do mine this weekend. It needs trimmed up desperately. I work on new power line transmission right of ways. We cut some decent sized water bars into our access roads to help keep them from washing out. I've noticed the airdam dragging quite a bit. If I don't cut it.. It might remove itself lol.
Thanks again!
AZCreeker
Pictures are a little deceiving as the concrete is sloped down. Covid and backorders made things fun for sure. Happy so far.
Bilstein 5100 (3rd ring 1.25”)
BFG KO2s 275/70R18
Fenders (before):
Driver Front 35.25, Driver Rear 38
Passenger Front 35.5, Driver Rear 38
Fenders (after):
Driver Front 37.5, Driver Rear 39
Passenger Front 37.75, Passenger Rear 39
So far no rub. OE wheels and even stock tires are super close to the UCA at full lock, if these rub it will be very minimal.
Any rubbing?
I have a similar setup but running 265/65r18 street tires, once these wear out, I would love to get some nice meaty at tires like yours!
Cadi_Mike
Austin TX
Here is my 15' Escalade! It has a 1.5" front level. 33x12.5 Ridge Grapplers. The tires just slightly rub but not too bad. Love the build. Just got all the chrome trim blacked out
nick14226
One more for everyone that could be helpful. 2” rough country up front, with the Yukon loaded with gear and xxl Thule up top was a little low in the back from the weight, toyed around with adding 1” spacers in the back. I ended up doing it (suspensionmaxx) and am very happy with the results. Subtle but i like it. Here are side by sides using a floor jack to simulate, left pics are 2” only, right pics are 2” front plus jacked up 1” rear.
BeenChevy
Minnesota
Looking good Nick. So all said and done you went with the RC 2" up front and 1" suspensionmaxx stack's in the rear? Did you install the shock extension brackets as well?
nick14226
Thank you!
Correct on the 2 front and 1 rear, my Yukon has standard shocks so I read no need for extensions. Getting in there and doing the install I concur there’s plenty of travel left and it feels fine on rough roads.
UNFMoose
I used the maxracing 1.5" kit off amazon. If you are planning on replacing the shocks, you're better off just getting the Bilstien 5100's as they are height adjustable. If my truck wasnt brand new thats what I would have done (its what I did on my Ram) Also trimmed the front air dam.
Did you use the supplied hardware with these? Any issues? Just ordered this same kit for the wife's 17 Tahoe.
nick14226
Nice!
Are those ridge graps the 305/45 xl’s? How are you liking them?
Thank you!
yes on the ridge grappler xl’s, and I sort of like them. I’ve run all sorts of aggressive tires on my lifted pickups in the past. These are very quiet for how aggressive they look. However I was hoping for a very smooth AT, and I feel some vibration at low speed (which is no problem) but high speed as well (75mph plus). Not a big deal for daily driving but on our 10 hour drive for vacation I was wishing they were smoother. And living where I do in Bufflalo, NY I’ll only run severe snow rated tires in winter, so these are summer only for me.
D Rollins
