clemenshess97
Berlin, Germany
Hey everyone,
I just bought a 03 Tahoe with some minor problems, one of them is the interior lights flashing when I hit the lock or unlock button on the key fob.
In the DIC I selected the exterior lights to be flashing when I lock or unlock the truck, I wish I could choose the horn to honk as well, but my truck was first delivered to Italy and I think they deactivated the honk option for european trucks.
Does anyone had this problem before with the interior lights flashing when locking/unlocking ?
BG1988
Hey everyone,
press lock twice it should honk (mine does not honk unless i press it twice)
Hey everyone,
Welcome to the Forum from NH.
Most folks here are very knowledgeable and more than willing to assist you with your questions and offer concrete suggestions, based upon their own experiences. @swathdiver @Rocket Man @PNW VietVet @Doubeleive
Folks will chime in.
Hey everyone,
is the fob oem or does it have some kind of aftermarket alarm system installed? maybe a previous owner wired the lights that way, check the drivers footwell junction box and see if there are any wires added that are not factory.
clemenshess97
clemenshess97
Berlin, Germany
the fob is OEM and the alarm system is original.
I thought maybe the BCM is faulty ?
that would be very uncommon, do the interior lights work normal otherwise? do they come on when you turn on the headlights?, have you checked for any additional wiring? I have a aftermarket alarm and I have it set to turn on the interior lights (on purpose) but only when unlocking/disarming.
clemenshess97
clemenshess97
Berlin, Germany
There are no additional wires. All interior lights come on when I turn them on with the dimmer switch and they come on when I open a door.
wjburken
Eastern Iowa
If you change your DIC settings and deselect the exterior light flash option, does that affect anything?
do the interior lights flash when you toggle the door locks from the drivers door switch? or only from the fob?
if you turn off the dome lights with the dash switch do they still flash?
do they flash during the daytime or only at night?
the questions are to try and determine if there is a fault or if maybe it was a feature that was programmed to the vehicle, like the horn honk being deleted
if it is a feature that was programmed to the vehicle then you might be stuck or maybe get lucky and find the circuit that makes it happen and hopefully disable it.
another option would be maybe if you have a gm dealer there in Germany you could ask for them to reflash the bcm for Germany, typically a service like that here in the U.S. would be around $100 usd.
jkhuntzinger
