GMC Canyon Wheels on 07 Tahoe
Vdubzr32
NJ
I’m new the the Tahoe scene so bare with me. I know the GMC Canyon is 6x120 33mm offset.
The OEM Tahoe LTZ wheels are 6x139 31mm offset.
the question?
Will a 1inch wheel adapter 6x139 to 6x120 work with keeping the Canyon Rim Flush with the fender on the 07 Tahoe. Has anyone done it? I tried the search function keep getting no results.
I’m also trying to calculate the change on some wheel offset websites.
I'm not understanding your 6x139 wheel size spec. For example, on my 07 Yukon XL Denali, my stock wheel size is 20x8.5 31mm offset. Can you clarify?
Regarding sites to calculate wheel/tire size changes, I believe that this is one of the best sites, as it allows you to measure and input the current actual clearances for critical suspension and fender clearances, and then see what the changes would be with a different wheel/tire size.
https://www.wheel-size.com/calc/
Vdubzr32
Vdubzr32
NJ
I’m not asking regarding wheel size. both wheels are 20in. I’m really asking regarding the offset is I use a 1 inch wheel adapter that converts my lug pattern from 6x139 to 6x120.
i don’t want the wheels to stick out past my fender. So will utilizing the 1 inch wheel adapter would make a 33mm offset wheel stick out past the Tahoe fender?
Sorry for the confusion.
Vdubzr32
Vdubzr32
NJ
6x139.7 is the lug pattern
yes that is my bolt pattern.
My current wheel.
20x8.5 Inch, 6x139.7 Bolt Pattern, One Piece Aluminum Wheel, Rim. Offset is 31mm.
i want to replace the wheel with
20" x 8.5" 6x120mm Offset 33mm
utilizing a 1 inch 6x139.7 to 6x120 adapter.
my question is. Will a 33mm with a 25mm adapter make the wheels stick out past the fender?
Bob LaFord
