Chasing a P0300
Cornelius
Charleston, SC
Long time lurker, seldom poster here.
2003 Yukon, 5.3l, 4wd, 215k
A few months ago it popped a p0300
It runs fine, pleanty of power, good throttle response, no other codes except for the p0300
I'm starting to run out of inexpensive parts to throw at it, and so far what I've done is what is expected for either maintenance or age/mileage:
Plugs and wires
PCV valve
Intake manifiold gaskets
Rear O2 sensors (no voltage detected but no codes either)
Checked vacuum lines, good
I could certainly keep going with parts, like MAF sensor, knock sensors, cats, FPR, Injectors, etc but I'm not getting ANY OTHER CODES!
Any guidance on where to start from here would be appreciated. I hope to find an app that will give misfire counts for each cylinder, then I can start swapping around coils.
Will knock sensors (or anything else) cause a p0300 without lighting a CEL with it's own code?
exp500
Even the Torque App will show enough live Data to figure out Where usually. Make sure you have the PIDS for GM installed. Kinda tedious to set up first time because you are adding so many monitors. Or start with a dozen and add more later.
BG1988
Plugs and wires
PCV valve
i'd check the throttle body have you tried cleaning that?
Air filter?
also check the hose that pops into the intake tube
Cornelius
Cornelius
Charleston, SC
Air filter?
air filter is clean
Throttle body I sprayed when I did the intake gaskets but yeah that would be a free one to eliminate
Which intake tube?
BG1988
air filter is clean
Which intake tube?
ah might be different on the nbs intake tube
but there could be a crack in it causing a leak
Cornelius
Cornelius
Charleston, SC
Throttle body is now clean
The vacuum line on pass side that appears to be a breather hose that goes from valve cover to intake was good but each end was a tad stretched so I hose clamped them on tight
does anyone know of a iOS app that supports misfire counts on each cylinder? I use a wifi ELM27 adapter
Cornelius
Cornelius
Charleston, SC
Still trying to figure this out. I don't drive it that much (company car) and life has taken priority but now I've gotten back to it.....
just to eliminate a cheap part i replaced the fuel pressure regulator
bought a fuel pressure tester, pump pressure is 50 when running so that seems good. holds 40 after an hour. not sure how much pressure is supposed to hold but i suspect it bleeds off back toward the tank.
Cornelius
Cornelius
Charleston, SC
Now I’m looking at the maf sensor live data but unsure of what is normal for how it fluctuates when RPMs change. The numbers are right from idle to WOT but I don’t know if the line on the graph is supposed to be a smooth slope, or jagged line
ivin74
05 NBS Nali
Htown, Texas
You need to find someone with a tech 2 and have them look at the live data. I'm willing to bet you have a bad coil.
Cornelius
Cornelius
Charleston, SC
I can see live data through OBD adapter and app. No codes for individual coils and when I unplug them one at a time I can hear the cylinder go down. Do better scanners read better? I know they can dive deeper but I was hoping that I can see enough through a phone app to solve this.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
You want to be able to look at a misfire count for each cylinder. there may be several doing it.
Cornelius
Cornelius
Charleston, SC
So maybe one coil or injector could be missing enough to set random misfire but not enough to set code for individual cylinder?
J Mac
Newport News, VA
I had the dreaded P0300 on my 04 Denali. Took it to 3 shops and since it was random, they couldn't figure it out. Dealership recommended a new engine...it actually says that on the ticket! Ended up being coil packs. Once I looked at those as a possible issue...I noticed the truck had 3 different types/brands of coil packs so I just replaced all 8. Never had a P0300 again.
mpope2
What’s the casting numbers on the heads? Maybe valve/seat issue that changes with temp?
ya I have ran into the same thing before, replaced all the coil packs problem solved. It was a gamble but it worked in my case
Cornelius
Cornelius
Charleston, SC
UPDATE
I had some time to keep messing with this yesterday and removed the injector rail to replaced the injector o rings and run some carb cleaner through them. I found a video online that used a tire valve stem with the core removed and after drilling a tiny hole in the cap the carb cleaner straw fits in and secured by epoxy. The injector top clicks right in to the end of the valve stem. Genius. I powered the injector with a 9 volt battery. Anyway, I did find that 2 or 3 injectors didn't spray quite as forcefully as the others, but when i was done they all worked great. Reinstalled everything, and yes it does run smoother, but still got flashing cel around 65-70 when backing off the gas. Also checked fuel pressure. 48 ign on not running, 52 running. Seems a bit low but it always starts right up, never had long crank problems. The spec is 55-60 so could lower pressure be causing a lean issue? But I would have thought low pressure would lead to issues happening on WOT or up hills, and times of demand, not coasting. Any and all opinions welcome!
Not sure if these fuel pumps work until they don't, or if it's possible that mine is getting weak and that's actually the problem. I hate to just fire the parts cannon at this. Dropping the tank isn't all that hard but most will agree that it's on the list of PITA jobs, and worse if the result is not different.
Done so far:
Plugs
Wires
Fuel pressure regulator
Cleaned injectors and new o rings
Cleaned TB
Checked and fixed vacuum lines
checked grounds
Fuel pressure seems low at 48 not running 52 running
NO OTHER CODES EXCEPT P0300
exp500
From what little bit you have diagnosed, looks like a fuel pump. Try finding fuel trims, short term and long term. Also do misfire counts on each cylinder. Swap two coils and see if misfire follows coil.
exp500
I should add- find the name of your app, go to their web page and find the instructions. Some are quite detailed. I don't have apple so can't help there. Make sure you have the GM specific codes loaded if thats an option.
Cornelius
Cornelius
Charleston, SC
Misfires are happening at 1, 5, 6, 8. Swapping coils makes no difference. I thought if I had a spark problem I would get a p030x specific to the cylinder not random p0300. I haven’t seen any signs of failing head gaskets. Other than this p0300 it runs great. No coolant loss, no coolant in oil, no gas smell in oil, normal oil usage (and rear main seal is seeping), normal exhaust smell, color and appearance.
BadDaddy2003
