The SMALL stereo Install
TARDIS
TARDIS
Jersey Shore
Behind the Rear Seat
Between the covered Spare and the back of the seat.
Sub pointing into the cargo area.
east302
Mississippi
OEM style HeadUnit
W/ added BlueToothView attachment 251011View attachment 251012
The new Headunit operates as the original did, with easy BlueTooth interaction.
I was most surprised at how loud the new unit is at only 22watts per channel.
These are supposed to be the original factory specs.
I guess my old OEM radio was just tired after 25years....and a little rusty
I had no idea these existed. How well does the Bluetooth work? Set it and forget it?
TARDIS
TARDIS
Jersey Shore
Once you choose a source, like your phone or an iPod, the HeadUnit will automatically connect to that source when you push in the BLUE button for BlueTooth.
Pushing the button lets me switch from AM/FM to BlueTooth. The headhunt always remembers the source paired.
I've turned the truck on and off a dozen times and it had connected with the original source every time automatically.
It takes from 3 to 5 seconds to pick up the BlueTooth signal. A distinct chime is heard, and the Headhunt is then connected to the source.
I'm using an old iPod. It works great.
One tip,
Set the source device to full volume, but a flat EQ setting.
Squirrelsmith
In other words, it’ll work just about like anything else does these days lol
If my $400 kenwood unit (2020) isnt set it and forget it i wouldnt hold out hope for this one. But who knows might get lucky!
TARDIS
TARDIS
Jersey Shore
It is set and forget it.
The BlueTooth is a pre-amp to the AM/FM.
Push the Blue button to switch back and forth, no matter how long the car has been off; it will reconnect with the last programmed source......
........like this super old iPod.
Luie
Id like to hear it in person. Bet it sounds really good.
MTN_KDA
