Towing my dead Tahoe
3BigDogs
Oklahoma
Hi I'm new here! I need some helpful advice!! I have a 2000 Tahoe LS 5.3 Vortec. Just put in a new battery and changed oil w/synthetic blend at Goodyear . I just made a 1,300 mile trip to help a military friend relocate from Ft. Sill to Ft. Bragg. On the way, at the gas station my truck wouldn't start again, after banging the starter with a hammer it started again. 200 miles later, my radiator suddenly sprung 6 small leaks and I immediately got it towed to a garage. Living on disability-meaning I'm poor-I had dude solder the holes (jb weld) which is holding, after I added Leak stop. Got to our destination and then my truck just stopped working all together. No lights, zippo! Don't know what's wrong
I need to get it home (OK) ASAP!! Would a uhaul flat trailer work? And what can I tow it with? Thanks!!
BG1988
check the fuses..you probably blew one check the BCM fuse and ECM fuse
or the ALt was not charging
3BigDogs
3BigDogs
Oklahoma
BCM ECM? sorry, where are they? and ALT not charging? could you be more specific? I'm not real familiar with this stuff. I can change the tires, spark plugs, routine maintenance, but being a single woman these 'computer' vehicles confuse me. lol
Big Mama
Virginia
For it to be dead suddenly, meaning no slow cranking etc it’s most likely electrical. I have the next model but the fuses you’re looking for are likely under the hood on the driver side and will be labeled BCM or ECM “ALT” is alternator. It charges your battery. Do a google search with your model looking for fuse locations. But as stated check battery cables at both ends first.
3BigDogs
3BigDogs
Oklahoma
I'm replacing the alternator, and fully charged the new battery. Hopefully this will resolve the problem..
3BigDogs
3BigDogs
Oklahoma
So after replacing the Alternator, charging the less than 2mo old battery, And replacing the freaking Radiator-yeah, that sprung a crap load of leaks 1 town out (5 hrs by myself), I Finally got on my way!! 19 hours later I got home!! (Ft Bragg to OK) Thanks Everyone!! :D
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Good job man.
new2yukon
Make sure the battery connections are CLEAN....and solid connected.
I had No-start issues on my lawn tractor that all boiled down to corrosion on my terminals that I thought was very very minor...well it wasn't. My new battery did nothing and then finally a real good cleaning on the connections gave perfect starts
89Suburban
SE PA
haha, actually i'm a 55 year old woman, 5'3" with collapsing discs in my spine, but Thanks!! ;)
I'm sorry. All my good will gestures get blown up in my face. Again, apologies. :oops:
HiHoeSilver
Away!
Chicago
yeah, it was a parting 'gift' from my ex-husband and his cop buddies in 06. He wanted a funeral instead of the divorce but I won ;)
Wow. Impressive. Glad you're home safely!
TejasPitt
