LT1ZOB
Put it up on my race ramps and applied my annual coat of fluid film.
Staggered 02
Polished the hood which was showing some water spot stains / cloudy. Aplied 2 steps of compound, washed then polished it. Hood and rest of vehicle looks great. Back to normal.
K2 Kaiju
The Depths
Found out the governor on my K2 burb is 110 mph vs 99 on the 13 avalanche...
Sent from my SM-G975U using Tapatalk
gat0r
DFW
^ that can be fixed w/ BBP tune
just be sure to get a better driveshaft first ;)
ours dont like much more speed
K2 Kaiju
The Depths
Lol, no way. Thats the first and last time I go that fast in a burb. Pretty smooth though...
tripreed
Maybe not today, but last week I purchased this 2016 Yukon SLT.
I've been driving a 2004 Land Cruiser for the past 5.5 years, so this was a big transition in a lot of ways. While there will be some things that I'll miss about the Land Cruiser, I've definitely enjoyed my time with the Yukon so far. And the improvement in gas mileage is already blowing my mind (I was getting around 12 MPG in my daily driving).
I'm looking at swapping out the 18" wheels for 20", and also looking into doing a leveling kit so that I can put 33" tires on.
sd172
South Dakota
You might be heading back to the same 12 MPG daily driving when you level it and put some aggressive 33s on. These rigs are dialed in from the factory to be as aerodynamic and fuel efficient as possible.
Example: 1 inch front level w/Bilstein shocks + AT tires 275/65 r18 + PPV air dam + Range AFM disabler + dyno tune on 91 and E85 = 14.5 MPG city on 91 or 12 MPG on E85 (measured at the pump).
tripreed
Wow, those is good to know, I appreciate that info.
BlackYukon
I'm kind of a Retard
If you Type "TahoeYukonForum.com" into google with the quotation marks, along with whatever you're searching for, it will show all the threads made on this forum that contains what you're searching for.
It would look like this.
DWTahoe
Colorado
@Billhicks1984 I don't think that's technically correct, but it probably shows some results. If you want to use google to search a web site I think the search is "site:tahoeyukonforum.com ac issues" but don't use the quotes. I think you'll see more than 62 results.
How to Search Within a Site Using Google
  1. Go to Google.com.
  2. Enter site:www.website.com search term into the search box.
  3. Refine your search.
BlackYukon
Thanks for the Correction. Someone told me years ago that was the correct way, I guess I just took it as factual without looking into it.
Bob2C
Northern VA
2nd oil change with RGT - hence 3 jugs: 2 qt left over from first change, a whole 5 qt, and 1 qt from 3rd jug. PITA. Was gonna just get a single qt, but it costs almost as much as I paid for these 5qts. Just wish I could get even 1 gallon jugs again...
Yeah. It’s a pain. I switched to the Amsoil XL because I can get gallon containers. The cost per quart when buying a case is more when you figure in the rebates gas truck has but for ease I like it.
Tiki
Oil change, air filter, cabin filter, shocks, tires, and thinking about a transmission fluid change. 36k miles is the new 100k miles.
TejasPitt
