mikeyss
The fans turn on when the compressor turns on so check to see if its coming on.
My fans will cycle on and off with the A/C compressor running, it just depends on how hot it is. When I remote start in the morning and it's 50 degrees, the compressor kicks on and the fans do not turn on tight away, the compressor may even cycle on and off a few times before the fans eventually turn on. However, in the afternoon when I remote start it and it's 90 degrees, the fans come on immediately and often will be on high speed.
The fans will work with the compressor about 80% of the time, its just dependent on outside temps. I know mine is working correctly because I just fixed my a/c compressor and my system is working perfectly.
