2020 Yukon XL with 5.3 will engine keep running ?
PG01
Up here to the right
I was locking our dog in our running Denail and the alarm kept going off. I finally realized that our rig has a motion sensor in it and Harvey was setting it off.
Da wif kept complaining of this too... no dog but the kids were doing it... there is a switch in the upper console that shuts off motion detector in truck
Gotta buy it by the ounce bro. You get enough to stay up for a week, then sleep for a day, and make sure there’s enough left over so when you wake up you can go out and make money (sell more car parts) to buy the next 2 weeks worth. Way better price by the ounce too. :cool:
me and a couple of friends used to have a running joke of "how many days did you sleep this month" :shakehead: all these tweakers now how no clue how good the stuff used to be back in the 80's/90's before the government started regulating the good chemicals
GotMechanicComing
GotMechanicComing
OHIO
Just wondered if you can lock doors and keep Yukon running with key in it and doors locked and how long will it run ??
PG01
Can’t lock with keys in it unless some is in it and physically presses the lock button on the remote. Door will not lock from outside if fob is in Truck. You can start it and take the fob with you then lock but it will shut off, I don’t remember the time limit but the truck shuts off on a regular start, person inside and idling after about an hour.
Hobert
Downers Grove, IL
Page 231 of the owners manual 2019 Suburban
Extended Parking
It is best not to park with the vehicle
running. If the vehicle is left running,
be sure it will not move and there is
adequate ventilation.
See Shifting Into Park 0 229 and
Engine Exhaust 0 232.
If the vehicle is left parked and
running with the RKE transmitter
outside the vehicle, it will continue
to run for up to half an hour.
inside the vehicle, it will continue to
run for up to an hour.
Page 43 remote start
Remote Vehicle Start
If equipped with the remote start
feature, the climate control system
will come on when the vehicle is
started remotely depending on the
outside temperature....
Extending Engine Run Time
The engine run time can be
extended by 15 minutes, for a total
of 30 minutes, if during the first
15 minutes Steps 1 and 2 are
repeated while the engine is still
running. An extension can be
requested, 30 seconds after
starting.
A maximum of two remote starts,
or a single start with an extension,
is allowed between ignition cycles.
AmazinglySmooth
I have never tried it, but can you switch from ignition to remote start? I had an aftermarket remote starter in a Toyota that allowed me to press remote start and then pull the key.
Sarah_279
PA
I wouldn't trust my dog's life with this technology but that's just me.
If
I absolutely have to leave him in the truck on a hot day, I will shut the Hoe off, exit with the fob and remote start it with the AC on (I believe it will run for 10 minutes unless you push the remote again but don't quote me.) and I will go out and periodically check to make sure everything is kosher if I'm going to be longer than 10 minutes. If something horrible were to happen I'd never forgive myself, and I'd hate for something to happen to your dog as well.
Mine is 100 pounds and not always very friendly, so I suppose I could leave all the windows down with him hanging out inside. He does not suffer fools, lol. I trust him, but I do not trust idiot people. :cool:
sealandsky
Minneapolis, MN
But they can still drive away with it, right?
It Depends... If the remote start was used, then you cannot shift in to gear without the FOB present. If it was already being driven around and then you hop out to for instance go in to a store, then yes it can be driven away.
Black Ice 2020
2020 remote start details from the owners manual
Bob2C
Northern VA
What I find is that when I remote start the ac will blow out of front defrost below the windshield. Nothing comes out of front vents and very little comes out of rear vents. Everything return to normal when I get in and press start button. Has anyone else experienced this?
gat0r
DFW
yes, my a/c does same
even the cooling seats operate differently.
fozzi58
North Jersey
Park your truck with the keys inside with the truck running. Get out and close door. Take out phone from pocket. Open up Chevy/GMC/Caddy App and remotely lock doors. Walk away. Doors will lock with truck running.
PG01
Yes app... forgot about that. And I lock it all the time for wife, who’s usually driving it, because she forgot if she locked it or not.
X-ray Nerd
