it should be good for life so unless you abuse it or by some slim chance it developed a leak then never.
I guess I should add if you blow the transmission up and it shoots metal thru everything then I would probably replace it there only about $100-120
But what about the hoses? They are made of rubber! Will they last for life?
no, you can have lines made if you want to get all fancy I just clamped mine, zero problems.If you already have the stock cooler, do the OEM lines hook directly up to this cooler?
