$42 HID out already
destroyer1362
A work in progress
Midlothian, TX
Long story short one of my HID's is out. How do I check to see if it is the bulb or the ballast? I can't hear the ballast humming on the side that is out, if that makes any difference.
Next question: If I were to get the 35w slim ballast DDM kit to replace this one, does anyone know what bulb color would be closest to the 5000k $42 ones? (they're fairly blue but I don't want to go any bluer)
Or should I just consider this a fluke and just order another set of 5000k $42 HID's.
Oh has any one else had problems with the $42 hids?
clean454
email the company
and check ALL ur connections first
if u have to unplug everything and re install it
make sure the plug is conneced the right way
the polarity mite need to be reversed
as the instructions show
destroyer1362
destroyer1362
A work in progress
Midlothian, TX
I'll check the connections.. but in the mean time you wouldn't happen to have the company email? I cant seem to find it in the site.
"350Vortec"
*Tahoeless, For now*
Never had a problem with mine in the 6 months i had them. Unplug the ballast from the working side and plug it into the bad side. Then try the bad one on the other side. Im guessing its the passenger side that doesnt work?
haks310
Got LEDs?
SoCal
First check your connections. If that doesnt work, disconnect the ballast that you think isnt working ahd connect it on the other side. If it works then it's the bulb thats out. If it doesn't then it's the ballast.
Sounds to me like it might be the ballast or the wiring leading to it.
If you do decide to get the slim ballast, you should be able to use the bulbs you have now.
HOUSTON
I would switch the ballast around or switch the bulbs around.I work on Hids and leds all day in Houston. The low humming could mean that the circuit in the ballast is bad. $42 hid kit sounds cheap.Cheap hid kits usually the circuit board and resistors within ballast are made cheap and have no waterproof/resistant at all.This is a problem alot of people are finding out.I know that like with the company i work for, we had to try out tons of hid kits to finally find out the one that we are going to go with because of problems like this. Also the plug and play kits are not really safe. I would put a heavy duty relay harness on the car to insure no shortings in your electrical system. Did you get a warranty at all?
foreverfalcon40
hate to thread jack but since we got some HID experts in here. My passenger side HID light takes a while to go on. Flickers...delayed kinda flash when I auto start. Bulb or Ballast?
destroyer1362
destroyer1362
A work in progress
Midlothian, TX
Its actually the drivers side
1 year.. If I can figure out how to contact the company
---------- Post added at 11:00 PM ---------- Previous post was at 10:51 PM ----------
I did notice the hid, that is out now, was flickering while it was warming up about a day prior to going out.
"350Vortec"
Any of you guys have constant power running from your batteries to the ballasts? Try buying the wiring harness from the same ebay seller. Its on the $42 hid site. That might help. Mine used to just shut off when i would switch to high beam and stuff. Sounds like yours just arent getting enough power period.
All ballasts buzz btw. its just how they are. They use electric field around a metal core to reduce power usage. That makes a magnetic field and that can change the shape of the core causing vibration. <---If i remember correctly?
bigblue
Beaumont TX
check all the connections, move the switch fron off to on positions a few times and see if they come on, my old truck was like that. If you dont have the relay i would suggest gettting one.
foreverfalcon40
Huh english...I need buy a relay kit to fix my problem? I have HIDS in healdights so no need to run highbeams EVER.
"350Vortec"
Another option is to just buy Toshiba HIR bulbs. I bought them for my Prizm. They throw ALOT. of light. But dont give that fake "illusion" of blue like hids. And you install them as you would any regular bulb. Give them a look. As long as you dont mind having the factory bulb color. I use it for safety.
black95
Freeport,NY
you don't need to buy a harness. i made my own 2 realys are like $10, couple connectors, some wire. works great
newmarketeod
I have the 55w kit from DDM and love it, haven't had any issues yet.
briannorris
