AC troubleshooting
PG01
Up here to the right
so it holds vacuum and no leaks, compressor kicked on but no cold air correct? gotta be inside then.... unless i missed something... blend door, controls. you have rear a/c?
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Yes It will be replaced since it's out and it's super easy to get to it's in the line between the high and low port. It had a little something on it but I could clearly see through it. Don't think it would cause nearly 500psi buildup.
Yes you are correct compressor is on front and rear is set to coldest setting and highest blower speed but completely warm air.
I think something was causing a pressure buildup which is why the service port began to leak and the air got warm while driving. Just not sure what would cause that. Maybe the compressor took and dump? Although it's coming on fine and sounds normal no weird noises.
PG01
i just reread your post you said dye was coming out of valve, maybe there’s dye and stop leak stuff gumming up the condenser??? in turn giving high high side readings??
just throwing ideas out
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Yes dye was coming out I assume someone worked on the AC system before or added a can of "AC pro" or whatever to try to get it cooler on a hot Texas day. It's very likely that could be gumming something up but strange that it would just suddenly clog it completely.
Might be worth it to reach out to @UmmScott . He’s pretty knowledgeable in the HVAC systems in these vehicles.
Send um in! I'll take any help I can get. Contemplating taking it to work tomorrow and finding a place to drop it off or taking the Taco and doing more research.
UmmScott
Omaha
Hopefully you pulled a vacuum and didn't leave that cap off! [emoji16][emoji16]
Forgive me if i missed something. You have front and rear ac yes?
You're pressures are Way Too Low especially at startup.
Even on a nice hot day with the front AND rear system on your low side will start up around 70 quickly pulling down to 50. And your high side will be higher around 250 and come down from there.
Are you getting the full weigh in charge in there? Those cans suck and aren't that accurate but should work if you get the right amount.
Btw 2 small cans is not enough for a front and rear system. I dont think you're adding enough especially with those pressures.
Another thing to help is to check superheat. Pretty easy on the front system. (Superheat is an indicator for how much liquid is in the evaporator and tells you how much work/change of state the evaporator is doing.)
Measure the line temperature right after the orifice going into the evap and measure outlet temp of the evap.
Subtract the inlet FROM the outlet. That is your superheat. If its really really high like 50F or even 30F, then you dont have enough refrigerant feed to the evap: ie low charge, restricted orifice. Superheat on a car should be anywhere from 0 to 20 once its cooled down.
Also (again sorry if i missed this) if you have rear AC. If the rear AC works pretty good but the front sucks or is warmer, you're low on charge. Rear system uses an expansion valve. Exp valves adjust and regulate themselves. The front orifice doesnt. So when system is low the rear will hog all the liquid available.
Hope this helps. Hit me up if u need more input man [emoji106][emoji106]
Sent from my SM-G975U using Tapatalk
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
I did leave that cap off for a good couple minutes until I realized it wasn't pulling vacuum hahaha!
I agree the pressures were low before I started messing with stuff but since the valve core was leaking I emptied the system, Vacuumed it for 30 minutes, then verified it could hold Vacuum for 15 minutes and began to fill the system. After putting just a single 12oz can in through the low side. The high pressure side shot way up to 450 with the compressor on. The high side port also got scalding hot and I was afraid it was going to burst.
Are you saying that more coolant will actually lower the high side pressure?
Yes it has rear AC and I did notice the rear was colder than the front as it was dying on my home. Never knew that was a symptom of low pressure though.
Thank you for the help! I know just enough to screw stuff up on AC:cheers:
UmmScott
Omaha
If your high side pressure shot up to 450 immediately then you got air in there man.
Whats the liquid line feel like when this happens? The line that feeds the orifice.
Is it scortching hot or cool with that head pressure?
If its cool then you 100% have air in there.
UmmScott
Omaha
Sorry sorry...just reread..
OK...SOOOOO....
your high side tap is right before the orifice.
If thats is getting scorching hot as well, then you got issues with your condenser coil.
Honestly, your compressor may be taking a crap on you. Generally when compressors start going bad theyll shed metallic material and internally plug up the condenser coil.
Feel your condenser. Make sure your fans are ON.
IF That condenser is hot you're not removing heat.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
The line that the High pressure side is on is scorching hot. I believe that is the the feed to the orifice.
Thank you for the help.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Whoops didn't see your second post.
Ok so my plan will be to grab a condenser, dryer and orifice tube on my way home. Install the new orifice tube vacuum the system and add some coolant. Check temp of condenser and then go from there. If condenser is clogged should I just bite the bullet and buy a compressor as well?
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
OK...SOOOOO....
Or plan B I can just order a new compressor, orifice tube, condenser and drier then rebuild basically the entire system. I can get it all delivered by Friday for 254 Amazon dollars. What r134 do you suggest?
UmmScott
Omaha
Honestly thats not a bad option.
Could do that. Just ensure everything is 100% leak free. Thats your main goal and you'll be good.
UmmScott
Omaha
Yes if that condenser is hot and isnt lowering your head pressure, and you KNOW....that you're leak free and have no air in the system...
Then yes that condenser internally is getting plugged in areas most likely due to your compressor.
Thats the only thing that will plug them up internally.
Get a garden hose on it while its running. Seee what happesn
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Since I found the parts decently cheap and all AC-Delco I'm just gonna do an overhaul.
What R134 do you suggest? This is on prime and has good reviews. https://www.amazon.com/gp/product/B07QKM49ZG/ref=ox_sc_act_title_2?smid=A1OYBDZNBHG2RG&psc=1
This oil looks decent as well https://www.amazon.com/gp/product/B00CFQQSJY/ref=crt_ewc_title_dp_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
dizhai
