M123
Viking
Sweden
I need suggestions. For the new(used) 6.0, what kind of chain and what oil pump should I get? Hv? Standard? It'll be a Melling tho. Suggestions, ideas?
Wouldn't it be better as higher you can get the oil pressure on this engines?
I think you will have less chance that sludge building up in lifter and pushing rods.
Just a thought. :)
mountie
Believe me, I'll be gentle--BUT--I just want to remind you guys that it wasn't my fault. Damn oil pressure. Carry on :driver::burnout:
Those neat burn outs you see on TV? The parts are sponsored!
The only sponsored part that you have that is not involved in a burn out is the A/C compressor. :emotions33:
I wouldn't stress the other Hoe's parts.
Maybe I missed it but whats the ETA on it running again?
:shrug:
Only my buddy and God knows! I just ordered some new AC Delco motor mounts. Can't hurt.
Lol, belueve it or not, I'm fairly gentle on the Hoe. Only when I'm tempted, then I speed--which is almost never :emotions33::angels25:
Got these--
Just curious--anyone know if the 07-11 mounts will fit the nbs?
Swapped my recalled HF jack stands out. Now my garage has +20 HP because red.
Also don’t let them tell you the 56369 6 ton stands are the same as the 56370 6 ton stands. The 70’s are bigger- bigger base and taller when collapsed. I found out after I got home so I had to go back.
treehan77
TYF Fiend
Crestview, FL
Not a great fit over the hump, but for $13 if anybody needs grey rear floor mats, price is pretty good. It’s better than the smallish Rugged Ridge universal ones I had back there.
Rugged Ridge 84951.10, All Terrain Floor Liner, Rear, Gray, 1999-2006 Chevrolet / GMC Silverado / Sierra 1500 Extended / Crew Cab, 01-14 2500 / 3500 Crew Cab, 07-13 1500 Crew Cab, Silverado 99-06 2500 / 3500 Extended Cab, Sierra 99-03 2500 / 3500 Extended Cab, 02-13 Avalanche https://www.amazon.com/dp/B00AMZPI8W/ref=cm_sw_r_cp_api_i_MUAXEbH8ADSQB
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
Saw this on the local offerup. Is this for the 03+ or 99-02? From what I can see on the "message center" is squared not round like the 03+, so it might fit my 01. What do you all think.
Phlipnstik
