Sunroof Rebuild
Matthew Jeschke
Sahuarita, Arizona
Okay, I'm going to need to start a whole new post for this lol So I've got my new to me sunroof track assembly in the roof of my Tahoe. I rebuild one of the gears for my stripped motor using JB weld while waiting for the good one to arrive. Motor works perfectly with JB weld fix.
However, track binds up. I cannot figure out why. It will go back to the full retracted position no problem. However, when I command it to come forward with the switch, it moves a bit then stops. For a while I could get it to come all the way forward, but it wouldn't tilt up (I need the mount to tilt up so I can install the glass.
Now it will only come part way. I used the allen key to overide the motor and push it forward. The track went forward, but wouldn't go up. I retracted it and tried again, but now the glass mount is stuck in the back of the track and the alen key override is stripped.
I'm waiting for the new motor to arrive, hopefully today. However, I'm at a loss for what's going on here. Motor is not binding at all, it's something else.
Video of me playing with it demonstrating problem:
https://drive.google.com/file/d/1oqNX06fgbd8K6ez_AaZK5fk6QU4S1FA8/view?usp=sharing
GMT800 2005 Tahoe Z71
Navy Supporting Member
I was looking for an aerial view of the track rail without the track rolling thru it. Wanted to see if there was a pinch in there. I am sure you checked though.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Tony, you may not be a sunroof guy but you were right lol I'll post a video... I got it figured out took a bit of careful fidgeting with the motor's manual override.
The bushing was seized in the leaver arm that extends the sunroof up. And the stop was sticking on the track. It needed a good lube. I cleaned it with dish soap and rags. Then liberally applied 3M Slicon grease and exercised the track.
Also I learned why so many people are stripping the gears and socket to manually override the sunroof motor. You have to push up till the gear set disengages on the sun roof. This manually overrides the motor. Otherwise it spins the motor and gear set when your manually moving the track.
Now I need to learn howto reinstall this factory wind deflector. It came out when I removed the sunroof from the truck in the junkyard. I looked at GmPartsDirect / factory exploded view of parts. Didn't shed much light. I'm watching youtube sunroof videos hoping to catch a glimpse of how it sat in there lol
You're almost there Matt. I give you an A+++ for your persistence and patience. Keep at it buddy, I'm positive you'll figure it out.
Never once in all the years I was in shops did myself as a tech or my techs when I was the service manager, deal with the sun roofs. I am now glad we didn't. Like Tony said, you have hung in there like a dog on a bone. This persistence is inspiring to say the least.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
I am really impressed with the design after fixing it a up. I'd be suprised if many of these broke.
I honestly thing the main failure mode is that gear set or perhaps a button. and of course debris in the drains. Otherwise it seems to be built very well.
I was just fortunate enough to have a truck with a highly jurry rigged sunroof lol
Sent from my SM-A505U using Tapatalk
satpoolman
San Antonio, TX
Hey Matt,
Did you ever figure out the reinstall of the wind deflector? While looking at cleaning my sunroof drain tubes, I noticed my wind deflector wasn't springing up as usual. The rear of the arms on either side of the deflector (on mine) look like they should be attached to the sunroof channel with small rivets, but appear to have broken off? The forward part of the deflector has a tab on either side that slide into small slots. I played around with the tabs/springs and was able to remove/reinstall the forward part of the deflector, but going to have to figure out a way to reattach the side arms in the channel. For the time being, I just removed the wind deflector so I can at least use the sunroof. Hope this helps.
E
adventurenali92
Big Bear Lake, ca
I never figured out my wind deflector issue either. It’s intact, no broken spring clips or tracks arms that attach to the riveted pieces. And it still doesn’t spring up and down like it should. I gave up on it. Lol. Everything else in my sunroof works as it should after replacing all the broken track and arm pieces that move the glass back and forth. And it seals like it should when I close it. But no air deflector. Oh well.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
same here... i havent devoted much time tho. i will post here if i ever figure it out :)
satpoolman
San Antonio, TX
This is where I'm at as well, removed the deflector and moving on. The weather lately has been awesome and I just had to revisit my sunroof issue, and this "fix" will work for me. Thanks for a little more insight on this subject. :cool:
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
I just need a friend that has a truck like this with the sunroof. Then I could look and see how that deflector sits in there.
adventurenali92
Big Bear Lake, ca
I got lucky and found a 2004 escalade in the junkyard last summer. It had a sunroof. That’s how I got the spring clips to replace the one that broke on mine. The deflector in that one was sitting jsut like mine. So I don’t know where to go from here. Lol. Oh well.... I can open and close my sunroof like it’s supposed to work, and I’m not really worried about the deflector. Haha.
Drewphil
