A/C issues
S
shegarty
Was able to check the low side and the switch is closed (no resistance). I wasn't able to get probes on the high side switch as it is pretty buried. Its pouring rain right now but when it lets up i can get the front wheel and splash guard off for better access.
Sent from my LG-US996 using Tapatalk
S
shegarty
I retested the low side after removing the splash guards as I could get a better look at the pins. It would appear that the switch is open (infinite resistance no continuity) which would indicate a low pressure situation and the need for refrigerant. I think I was crossing my leads earlier as I couldn't get clear access to the plug.
The high side switch has three wires. ~40 kΩ between all combinations. Can I assume that the high pressure switch is faulty or is this reading accurate for a low pressure situation? [emoji44]
UmmScott
Omaha
So the high side switch has three wires. ~40 kΩ between all combinations. Can 8 assume that the high pressure switch is faulty then? Don't like my odds of getting it out though ... [emoji44]
No. That's not how a 3 wire switch works. Thats a transducer generally.
That switch will do 2 things. A... Tell the PCM what the system high side pressure is by producing a varying voltage proportional to system pressure. PCM will then turn the rad fans on high/low as needed or even off.
And B... too high will shut the compressor off.
Is it bad? We dont know. Cant really jump them out to test.
Sent from my SM-G975U using Tapatalk
UmmScott
Omaha
But that's odd.. you said you have a rad clutch right? So theres no rad fans..
Hmmm
S
shegarty
I was editing while you replied. Looks like i am low on gas as the low pressure switch is actually open.
UmmScott
Omaha
Ok cool...
I cant remember the cut in point of that switch but..
Awesome im glad you figured it out man
DenaliReyes
Detroit, MI
Just the thread I have been looking for. Will try all your steps. I bought a multi meter. I gotta learn how to use these things lol
Thanx
Drewphil
