tech 2 question about auto headlights
HACK BLOCK
NYC
could I use a tech2 to adjust the sensitivity of my auto head lights?
I don't think the tech2 can be used to adjust the sensitivity of anything other than for temporary testing/troubleshooting purposes, it could be used to re-calibrate them if it has that option. my 2012 does not have the auto high beam function (if that is what you mean) if you are talking about when they turn on/off at dusk or dawn then probably nothing you can do there, that function operates from the sensor in the dash (looks like a little bubble in the front center of the dash near the front window) if that has sunken in it could be the cause,
veteran111
