Trans Temp sensor replacement 8L90 8 speed
XSELLR8
Here is my DIY for replacing the temp sensor harness on the transmission (common on the 8L90). It came up as code P0711. it was causing hard shifts when warm and felt like the trans was slipping as well. Now its perfect!
SuperOldSchool
nice work! When you filled the last quart after letting it run a bit- did you add the quart while it was running or did you button up the fill plug and shield, run it a bit , then remove shield and plug again?
I’m wondering if you can run it a bit with the plug out or will fluid spray out all over?
Thanks!
I had dealer change filter and fluid at 45k, it’s time to do it again and I want to do it myself this time.
Thank you!
SOS
XSELLR8
XSELLR8
Thanks!
Thank you!
SOS
I started it up for a few seconds so the fluid would get drawn in, then added the last quart. It’s too hot to add it later in my opinion. If you pull the fill level bolt and nothing comes out I would wait until it’s cool, add some more, run it around the block again and then pull the plug. Just my preference.
SuperOldSchool
Thanks for the quick reply. Just so I’m clear, you left the fill plug out (not the level check plug) , started the engine for a bit, then shut off engine and filled last quart in the already open fill hole?
After that, you buttoned up the fill hole and checked fluid level while trans was at operating temp. Right?
Thanks!
XSELLR8
XSELLR8
Thanks!
Correct
enigmaspeed27
