My left flasher speed very fast
jdpromo33
Proud Tahoe Owner
Bloomfield, New Jersey
I just drove the truck and when I made a left turn, the flasher is going at double speed. Right one is fine.
I looked at the lens where the turn signal is and the glass is all misted up inside.
Could it be moisture in the bulb connection?
Thanks
Effeckt
Resident Cards Fan
Phoenix, AZ
Usually it does that when a bulb is out. I would check to see if either your front or rear bulbs are burnt out.
Effeckt
Resident Cards Fan
Phoenix, AZ
Are you using the stock bulbs or leds? LED's have a different load resistance and can cause that issue as well. Or maybe the fuse is going?
jdpromo33
jdpromo33
Proud Tahoe Owner
I guess even though they are both working it still could be a bad bulb.
No I'm still using stock bulbs and I'm sure the misted up lens has something to do with it.
Thanks guys
chistoso
Arizona
If you are using LEDs you need load equalizers for them and if not I would begin with checking every light bulb. Does it flash fast with the turn signals of the hazards activated??
jdpromo33
jdpromo33
Proud Tahoe Owner
Not using LED's just stock bulbs and the hazards work fin at the right speed. just when I use the left turn signal they flash very fast
---------- Post added at 05:34 PM ---------- Previous post was at 04:27 PM ----------
They let in moisture so I need to replace them.
What do you think of these LED bumper lights?
cam3439
You can get a sense of what they look like if you look up member titanium02. His have a chrome backing to it and isn't black like what you posted.
NJ04HOE
Paterson, NJ
Get'em!! I've had mine for about two months and I love them, I have the chrome/clear ones though. I think the black ones would look sick on your truck.
I don't have many pics because of the weather, and i'm waiting to update my sig pic once the wheels go back on. The only problem I've had with them was they were starting to fog up after a week or two so I took them off and resealed around them on the back with silicone.
Here's a pic
Oh yeah Titanium was my inspiration BTW
Durobans
