3” lift spindles or rough country 3.5” lift?
massivespl
I'm not mean, I'm honest.
Michigan
BBBF9023-FE76-4CA2-94F5-C4EAB7C87CA6.jpeg https://spindle-source.com/2007-2014-chevrolet-avalanche-1500-chevy-tahoe-2wd-3-lift-spindles-knuckle/
If I get these 3” lift spindles can I use my stock control arms? Or do I have to get new ones? Also should I do these spindles or should I get the rough country 3.5” lift kit.?
I got some 24x11 wheels I’m trying to stuff under my 2014 2wd hoe.
massivespl
massivespl
Michigan
Dang u guys are helpful :bs: I ordered 3” lift spindles. I’ll see if that gives me enough clearance
Z0lan0
SoCal
No these spindles pissed me off. Lol it made the rim offset stick out even further and wouldn’t clear. With the lift spindles and stock wheels it was like -50 offset. It’s weird.
Nice ride!
So did you have to drop the transfer case? Did you end up buying additional hardware for the 3" arm to fit? Are you running just the 3"control arm or have a lift kit/spacers?
Im planning on doing that as well on my Tahoe, and add a 2" leveling strut on the front. Save some money rather than buying the 3" lift kit. Im just trying to avoid cutting the transfer case and dropping, if there is a way.
Austinite
Austin, Tx
Do you have any more pics? How much further does the front wheels/tires stick out than the rear? I've done the 3" lift spindles on a 2000, but not my 2007. What size are your tires btw?
massivespl
massivespl
Michigan
96F0E5E6-B728-4639-9951-0F42B5F619A5.jpeg BB4F5073-902C-43FE-B36B-512549B63E8B.jpeg
These are 265/70/17.these tires look nice until u park next to some 305s/33x12.50... and then they look tiny skinny
massivespl
massivespl
Michigan
I think I might try stuffing some 24” wheels stock offset with 33x12.50r24 tires. The 24x12 with 305/35/24 just were to damn wide with the lift spindles. So I think 24x10 stock offset the wheels should fit. Prly spring time
DesertGator
