3” lift spindles or rough country 3.5” lift?
massivespl
massivespl
I'm not mean, I'm honest.
Michigan
Dang u guys are helpful :bs: I ordered 3” lift spindles. I’ll see if that gives me enough clearance
massivespl
massivespl
Michigan
Did the spindle give you enough clearance?
No these spindles pissed me off. Lol it made the rim offset stick out even further and wouldn’t clear. With the lift spindles and stock wheels it was like -50 offset. It’s weird.
Z0lan0
SoCal
Nice ride!
So did you have to drop the transfer case? Did you end up buying additional hardware for the 3" arm to fit? Are you running just the 3"control arm or have a lift kit/spacers?
Im planning on doing that as well on my Tahoe, and add a 2" leveling strut on the front. Save some money rather than buying the 3" lift kit. Im just trying to avoid cutting the transfer case and dropping, if there is a way.
Austinite
Austin, Tx
Do you have any more pics? How much further does the front wheels/tires stick out than the rear? I've done the 3" lift spindles on a 2000, but not my 2007. What size are your tires btw?
massivespl
massivespl
Michigan
These are 265/70/17.these tires look nice until u park next to some 305s/33x12.50... and then they look tiny skinny
massivespl
massivespl
Michigan
I think I might try stuffing some 24” wheels stock offset with 33x12.50r24 tires. The 24x12 with 305/35/24 just were to damn wide with the lift spindles. So I think 24x10 stock offset the wheels should fit. Prly spring time
massivespl
massivespl
Michigan
Just bought some 24s with 33x12.50r24 MT tires. Should be here next week.
Kee Fuller
las vegas
Very intrested in the outcome of this. Im doing the 24 inch black snowflakes on 33x12.5/24 tires as well.
Looking at the rough country 7.5 lift kit
massivespl
massivespl
Michigan
7.5” lift on a 33” tires is gunna look super super small. In my opinion. Get 35s forsure
massivespl
massivespl
Michigan
what kind of lift does the Tahoe have in this pic?
lol well it started its life as a PPV Tahoe which is like 2” lower from factory. I lifted the front 3” with spindles. So that’s basically stock height lol.
GreyStone
Do you have much rub...can you make U-turns?
Drewphil
