2007 Tahoe Heater Hose - Quick Connect
Plimbob
Des Moines Iowa
My 07 Tahoe had the heater hose quick connect break and I was going to replace but my dis-connect tool doesn't seem to work worth a darn on it.
It seems like it should be pretty straight forward but not working out that way. It's the black connector not the white one.
Is there a trick or something I am missing on this procedure?
89Suburban
Bull in the china shop
SE PA
I don't have luck with those either, I always wind up having to break the plastic pieces that hold the keeper in place with side cutters or needle nose pliers or even a large pick tool or flathead screwdriver.
jz57
Attn: Plimbob
See the following link:
https://www.tahoeyukonforum.com/threads/gruven-heater-core-t-connectors.107087/page-13#post-1302085
Post # 126:
NO special tool required, need following 3 actions to remove Quick Connect (QC):
1) Push QC toward firewall
2) Squeeze White tabs with Thumb and index finger
3) Pull the QC
Action-3 has some trick, the white tabs could be stuck on the heater core inlet/outlet pipe barb, it will be very difficult to perform Squeeze & Pull by one hand. So you may need a 2nd hand or a helper to perform Action-3.
It may help removing the fittings by spraying some WD-40 between White tab and heater core inlet/outlet pipe.
Post # 128:
Please see the following pictures, 2 people’s job, one squeezes the white tabs, and the other one pulls the string.
