05yukondenali
- Joined
- Jan 15, 2020
- Posts
- 5
- Reaction score
- 1
My 2005 Denali's sunroof is in need of repair. It will work, but only one side will slide barely slide open before it stops sliding altogether. This is not the problem though, I was wanting to seal the sunroof because it is leaking into the cabin. Also, a good bit of water will come out of the drivers side rear vents if the Yukon is parked nose up after a rain storm, which I believe is being caused by clogged drains. My question is, if I silicone the sunroof shut would water still run down into the drains? If it would, I would first have to remove the sunroof glass because of the opening issue, blow the drains out, and then silicone the glass. Thanks
