Cheap parts before off to scrap
HiHoeSilver
Away!
Chicago
You should also grab yourself the front impact sensors if you didn't have an airbag light on. Them little buggers fetch good $.
1badc4
1badc4
Yes sir, I agree slop likely associated with steering box, idlers, tie rod ends etc..
Price is fine. LMK what you find and I'll get funds sent. Thanks.
i'll pull them off tomorrow morning and get a price at post office. I have other parts to ship. hoping to send this thing to scrap next week
1badc4
1badc4
What audio system did it have in it? Standard with the amp behind the glovebox?
Hmm?yes is was standard non bose with sub. I did pull something that looked like an amp from behind glove box. is that what your looking for?
the shield that shares holes with skid plate?
I think so, the splash shield that covers the gap between the radiator and engine has 4 bolts and I think two of them are shared with metal skid plate and then if you have them, the bolts for the transfer case skid plate.
1badc4
1badc4
I am positive I have them. i think I st them aside with that splash guard and skid plate because a guy was suppose to buy them for a 30 pack of Coors light but no show. if I didn't set aside they are in the bucket i have with all bolts I took out from engine swap. I'm going to pm you with my # if you want to text me when I am done work around 615 I'll verify.
Staggered 02
Okay sounds good. Send me the total and I'll send send you the funds. Thanks.
HiHoeSilver
Away!
Chicago
where are they located?
Behind the front bumper. There's one on each side. Look like this:
1badc4
1badc4
I went out to check it out I see the part that connects to steering box and other end connects to column about 12-14 inches long. how does the other part get removed?
HiHoeSilver
Away!
Chicago
I'll pull it off tomorrow. lmk if you find out if it works.
Theres 2. Grab em both. Pass & driver. Will take 30 seconds.
If possible could you post up the part number on it? Once you get it off. Thx
Theres like 3 or 4 part numbers that cross to each other. I have them. Will watch this and help.
Do the Team TYF on this one. Those stupid things are $50+ used on fleabay. I got lucky to find one for a little cheaper.
Thx Nate. My driver side is bad--on both. Must be a common issue.
TejasPitt
