Cold? Viper 5701 2 way car alarm $102 Reg $499! I GOT ONE !
Riff Raff
Arlington,Tx
my guy fixed it today. check engine light is still on for now. i just need to go to autozone and clear the codes. your guy was close to the problem. he wired ignition 1 and igntion 2 up backwards. took him 10 minutes to fix it.
i followed the instructions online on how to keypad lock the remote but cant get it to work. this remote is finicky!
Im glad you got it going,link to the keypad lock?
I cant seem to find it for my life,all i find is to unlock it which is function then press unlock
DenaliAK
Colder than you
Alaska
The check engine light might go off by itself after a couple of more clean start/stops with no codes. At least that's how my other car works.
He was pretty close to the problem. Not bad considering he's never seen your rig and we're about 3,000 miles away...lol
I'm glad you got that straight, though. That would be annoying.
Edit: I think Riff Raff and I were typing at the same time. Didn't mean to completely duplicate his question....
On the keypad lock thing, where'd you find the info?
---------- Post added at 07:02 PM ---------- Previous post was at 06:55 PM ----------
I just dug around a bit and found this. Maybe someone can try it to see if works.
Supposedly how you lock the keypad buttons (sounds oddly complicated for such a seemingly simple thing):
For keypad lock press F for 12 seconds. then when the LED light on top turns red press the unlock button for 1.5 seconds. After that press the lock button and the keypad will light up for a few seconds, leave it alone, when all the lights turn off the keypad is locked.
Riff Raff
Arlington,Tx
Denali last time i held the function button for that long it de-programmed my remote and i had to reprogram her,so im a little scared holding it down for that long lol
DenaliAK
Colder than you
Alaska
lol
Ok, bear in mind I got this info from a review and have no way to verify it.
So, do at your own risk. Could be a load of crap someone thinks is funny.
I'll ask my installer when I talk to him next.
---------- Post added at 07:36 PM ---------- Previous post was at 07:12 PM ----------
Alright. I don't have mine fully installed yet, so I can't play with it, but here is how you set your remote to automatically lock the buttons after 60 seconds. This is straight from the manual:
To program the remote user features:
Press and hold the function button for 12 seconds: (at 3 seconds ignore
the Car number indicator.)
The remote emits one long beep, and the Transmit LED turns on.
This indicates the Main menu.
Press and hold the unlock
button for 1.5 seconds:
The remote beeps two-times, and the Transmit LED blinks
two-times and stays on. You are now in the Remote Configuration
menu.
The Arm, Disarm, Remote Start & Aux LEDs will turn ON, and/or
blink to indicate the current remote feature configuration. When
the LED is ON, the feature is ON.
To configure the remote control features press and release the
command button. The LED next to the button will turn On then OFF.
The remote beeps to indicate the feature configuration.
Lock Button: Auto-Button Lock.
When Arm LED is OFF, buttons will not lock.
LED ON: The buttons automatically lock 60 seconds after the last
button operation to avoid accidental Command operations. When
locked, if any command button is pressed the remote will emit an error
output.
If button lock is ON, press function, and then unlock
buttons.
I had to edit some of that because it uses pictures. If you need clarification, go to: http://www.directeddealers.com/manuals/og/viper/G5202V-2008-02.pdf
Scroll down to the Remote Control Programming section.
Narco
Atlanta
i held the f key for 12 secs and then hit the lock key. it was supposed to set it up to self lock after 60 secs but that didnt work. i cant find info anywhere how to lock it
the installer said that the engine light would go away on its own after a few days once the computer learns the bypass is supposed to be there
DenaliAK
Colder than you
Alaska
Think you skipped a step, where you hold the unlock button for 1.5 seconds to put it into menu mode. Then hit the lock button, and theoretically it should work.
Riff Raff
Arlington,Tx
wooooohoooooo!!!!!! it works!!!!!!when its lock it gives the red error buzz and you cant do anything,hit F,the unlock lights up green,hit unlock and all the led's light up from bottom to top with a confirmation tone letting you know your remote is unlocked.Already did this a dozen times.
Thanx guys!!!!!
DenaliAK
Colder than you
Alaska
Yays!
I figured something out....lol.
Glad it works. Narco, there's your answer (up a few posts in red).
Narco
Atlanta
trying it again now
---------- Post added at 12:27 AM ---------- Previous post was at 12:21 AM ----------
damn it, i followed the steps...still wont lock
hold f for 12 secs, hold unlock for 1.5, press lock and make sure the led is lit right? what am i missing?
Riff Raff
Arlington,Tx
trying it again now
sounds like your good bro wait about a minute and hit any button,should give you an error tone and function will light up red
Narco
Atlanta
nope. i wait and wait, go to the window and hit the unlock button and my car unlocks. its pissing me off.
---------- Post added at 12:52 AM ---------- Previous post was at 12:44 AM ----------
got it...finally. i didnt see where you have to hit the f key again after doing all the other stuff
Riff Raff
Arlington,Tx
sweet glad you got it,yeah that function button you have to hit to get out of the menu you were just at
Narco
Atlanta
i wish you could lock it automatically by hitting f and the lock button
DenaliAK
Colder than you
Alaska
That'd make too much sense and be too easy.
Hopefully, in about 2 hours mine will be done being installed and then it'll be my turn to get pissed at the "lock buttons" function on the remote.....
Narco
Atlanta
get it done? i finally got the remote set up how i want. i turned off those stupid tones that beep at you everytime you hit a button. this weekend ill set the sensitivity where i want it.
Noto81
South Dakota
Anybody have any pros/cons on a compustar keyless entry/remote start/security system? I'm getting one tomorrow. Not sure on model but it have 1500' range and the 2 way receiver with the lcd screen.
DenaliAK
Colder than you
Alaska
Got mine done last night. Honestly haven't had time to play with it yet other then a basic check to make sure things worked.
FWIW, it is highly programmable. You can set a low temp (which is what I thought but nobody seemed to buy) where it'll autostart to warm up. Mine is set to turn on at 0 degrees for 15 minutes every three hours. You can also do the reverse and set a high temp to cool the car automatically.
I also have mine programmed so the shock sensor is off. I hate false alarms and unless you make it into my car I don't want to hear about it.
It also monitors battery voltage constantly and you can set it to start the car to charge the battery if it goes below whatever voltage you set it at. I thought that was a nifty feature. I think it factory defaults a lot of these settings, but you can change them to whatever you want. All in all it has a lot of functions.
As for the Compustar, I have one in my other car and ir works fine although it's claimed range is not near reality, and it seems a bit weak in that regard. Often won't start from inside stores even though I am well within the range limits. Other then that, no issues with it and it's manual.
Still have to play with the viper remotes. One came with dead batteries so can't do anything until I get new ones.
DenaliAK
Colder than you
Alaska
Alright, found my first issue with this: I lost driver recognition. If I autostart then turn the key nothing reverts to that keys preferences.
Anyone else have that issue?
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
I think that is normal.
couple of questions that might provide a solution or alternative solution.
is your preference set to key IN, or remote on the DIC? Have you tried the other setting?
can you retrain yourself to punch the driver preference on the door?
How about turning off the Easy exit feature so it stays at Driver ___ until you change it yourself?
Narco
Atlanta
i hate the easy exit feature... and i could always hit the #1 button if needed. but to answer your question i did not lose driver recognition.
Hodmjstone
