Where to buy LED puddle light?
Mvfootball1
Shoreview, Minnesota
Yes, I read the sticky post above. When I want to the site, I could not find the type of bulb he lists for the puddle light under the mirror. Am I just not seeing it?
Does anyone know anywhere else to buy them? I want blue
yukondoit
Stay Classy
Flagstaff, AZ
superbrightleds.com
Here is the info for the puddle lights. I have these same ones.. :waytogo:
37mm, 3710 x HP6 festoon bulbs
M
Mvfootball1
Hmm...maybe they're discontinued. I searched the website high and low. I guess if anyone can find them and could post the link to them here, thatd be sweet
ICON
Bellingham, WA
They're on the www.shopcustomcreations.com website above. They are listed as 194 led lights in the LED section. They are the same bulbs as the license plate lights. Double check on www.sylvania.com to see if your yukon uses that type of bulb first. I know it is the correct bulb for the 07+ Tahoe/Yukons.
M
Mvfootball1
Ahh yes found them, now when they say quantity "1" does that mean 1 set, or literally 1 bulb? Lol I hope its for set, or im going to feel sinful for spending 30+ dollars on puddle lights
yukondoit
Stay Classy
Flagstaff, AZ
Haha, yeah 1 means 1 little bulb. So you're looking at about $30 for just the puddles. (2 bulbs).
ImPrettySnazzy
Someone should post pictures of the new bulbs in.
Im tired at looking at my nasty yellow ones and want to see how this turns out.
l2yan
I got mine on ebay when I did the puddle light mod for $10 a pair. Still shining bright. Look up 578 LED Festoon. Just make sure you get the correct length.
---------- Post added at 03:51 AM ---------- Previous post was at 03:50 AM ----------
Here's a Vid of mine in.
http://www.youtube.com/watch?v=OEYtNackLiY
---------- Post added at 03:53 AM ---------- Previous post was at 03:51 AM ----------
http://stores.ebay.com/jdmautolight
Way cheaper and good quality.
rarickli
I attached interior LED and the puddle light LEDs that I installed tonight. Took me 15 min to install. Super easy. (Ignore the Halloween Decorations in my garage haha)
Esky taillights installing Friday, and 5% tint all the way around (I have 20% all the way around now). 24" wheels coming next month.
05Single
afraid of the dark
thats a lot of spider webs...your spider man aren't you !!! :D
Pscott
milwaukee wi
Would it be hard to add puddle lights ? Is the wiring already in place I don’t have them now
you can just run a wire from the interior light harness at the drivers side kickpanel thru the rubber boot in the doors and then just ground the other end to the door.
when you unlock the door with the fob the puddle lights will come on same as the interior lights or when you open the door, etc. you can add turn signal mirrors the same way.
05Single
afraid of the dark
I would splice into the door courtesy lights . No fishing through boots.
I didn't have them either. I bought some mirrors with the built in signals and puddle lights. They plug right into the master window switch. Everything will work like they should.
briannorris
