Oil and filter recommendations
DaRosa218
The Dude abides
Modesto, California
it has a
GM went to the future and came back with the variable oil pumps ..
If you google viable displacement oil pumps it will only refer back to 2012 as being new tech.
it's a high performance oil pump for the Lxx engine
it's a frankenstein LS2 based engine RPO LFA and LZ1
It’s available under p/n 12625823 for the LFA and p/n 12623423 for the LZ1
apparently it saves 2 HP from being wasted :)
HP is
332 hp @ 5100 RPM(248 kW) 367 lb⋅ft (498 N⋅m)4100 RPM Combined output is 379HP/ 472 lb-ft..
some people might consider this a VERY HIGH OUTPUT engine lol
VHO 6.0L
it has a 4 or 5" aluminium drive shaft it's big though i'll measure it later
Ok, so you have an LQ9... got it. LOL
DaRosa218
The Dude abides
Modesto, California
RPo LFA it has VVT and AFM aluminium block
basic slapped random parts together and built them
So you have the hybrid motor? LFA's were factory options in the 2008-2009 Hybrid SUV's/Trucks. The LZ1 replaced the LFA in 2010 for Hybrids
HiHoeSilver
Away!
Chicago
Yes. His is a hybrid. It's a super special magical one. It is both the greatest vehicle GM ever built and a total piece of junk that he is lemon lawing. Dont ask him about it.
HiHoeSilver
Away!
Chicago
BG1988
you think this is satisfactory and safe when you buy something that is proclaimed as being in satisfactory condition and "safe"
I asked for the records for the SUV they refused because they claimed the dealership owned the "inspection records"
they know they are SCREWED as the records are FALSE.
they even did a illegal smog test as well. (at lest it would have failed the physical inspection part) DRY wall screws holding up fuel housing/ hose
very legal and safe if you ask me (if you did not know I was being sarcastic )
a
Nap73
Nap73
No not lemon lawing it they sold it to me with BAD brakes and was possibly in an moderate accident with airbag deployment... THEY SHOULD PAY ME BACK for me OVER PAYING and screwing me with faulty brakes
if the air bags have been deployed the VALUE should have been quite a bit less
Minus $3500
they also Vertical tied another item to the sale of the SUV which is also a violation of FEDERAL LAW :
minus $1100
So i'm owed 4.9k (including the cost of replacement of the brakes )
Section 1 of the Sherman Act is the federal antitrust statute most often cited in vertical restraint cases. Section 1 prohibits 'every contract, combination in the form of trust or otherwise, or conspiracy, in restraint of trade' (15 USC, section 1 (2012)).
The vehicle was advertised as being Safety OK
How safe is a 6000 pound SUV with faulty brakes they also LIED under penalty of perjury Which is a FELONY and stated the actual mileage being 840,000 miles.. onto the title...
This is PERMANENTLY on the TITLE History it NEVER goes away
New 12V+ battery corrected the electrical issues.. :eek: :rolleyes: I have not had a problem since electrical wise...
Thou shell check the voltages when troubleshooting.:whip:
also for the current engine issue that was cause by the idiots at the chain shop THEY destroyed my engine they forgot to tighten the oil filter and plug screw and the oil was lost over a short distance of 164 miles
it knocks on Bank 1 cylinder #3 or #5. and heavy valve clacking on bank 1.
IF I WANTED TO GET RID OF IT I WOULD HAVE CRASHED IT ALL READY I could have gotten a pretty nice pay out of 1.01million(or more) dollars By forcing the person that was tailagting me to push me into the 18wheeler that ran the stop sign..(fail to yield to right away traffic)
few weeks ago
It was set up perfectly i was just 1 second off other wise I would have hit the rear wheels of the tractor without slipping under the trailer. I ended up getting down from 55 to 10 and moved carefully off the road slightly (did not want to get stuck in the dirt)
also for the fun of it today a van that was tailgating me I forced him to eat some large rocks into his VAN that is what he gets He blew out two tires on his van after running them over. Instant karma :rotflmao: I hope he learned his lesson and has to pay a lot of money to fix it...
My brain is powerful I can instantly calculate geometry and physics In real time I may not know how to do it in the written format but can apply it to real life situations... that is what counts anyways.. :jawdrop:
:fuckyea:
840k miles ??
BG1988
840k miles ??
yes they fudged up they should pay for the damage the was incurred on the title...
and removing invalid or mistake data from carfax is nearly impossible
( if they did ,it would invalidate the service)
DaRosa218
The Dude abides
Modesto, California
I'm sure it has a lot to do with your LFA being AFM with VVT and my LY6 is non-AFM with VVT
Sent from my Pixel 2 XL using Tapatalk
wjburken
Eastern Iowa
Minus $3500
minus $1100
few weeks ago
:fuckyea:
The Whip
