Oil and filter recommendations
GMT800 2005 Tahoe Z71
Navy Supporting Member
I like watching that dude's videos. :)
Yea so do I
I was pleasantly surprised by the outcomes of the combined tests. I have used the Amazon Basics full synthetic now for the last 2 oil changes. My oil pressure is rock steady and no engine noises that I would relate to an oil or lifter problem. I order it, it gets delivered right to me for free shipping. These tests prove to me that I can drive with the confidence that the oil is doing what it is supposed to do and holds up as tested.
Nap73
Nap73
I just changed my oil
I Used :
Shell Rotella 5w30 5 gal $21.99 Walmart.
K&N filter HP-1017 $12.99 Walmart.
I’ll let you guys know if I feel / notice anything different.
I've thought about the filter thing the last few times you've mentioned it. Wouldn't lower pressure mean the "better" filter? Curious of the data on the K&N. It doesn't seem to be published. What makes you say it has better filtration?
The M1 EP filters have a micron rating of 30 and trap over 99% of particles this size. It's flow rating is 672 GPH. The K&N filters down to 10-12 microns and flows 960 GPH. It took some time to glean this information from multiple sources across the internet.
The K&N HP-2011 will fit my rig ? Because on the site it’s showing that it won’t. I’ve got a 2007 GMC Yukon XL 2500 it’s got the 6.0
Yes, it will fit your LY6 too. These motors were designed to run the short filter but will safely run the longer filter which is what GM uses in the V6s and Gen V motors. Notice, the chart above includes only premium filters but for thirty plus years I've used FRAM and Pennzoil without issue in other autos. For this particular truck in our stable, my desire is to run the premium stuff.
Nap73
Nap73
wound up getting the shorter one ( HP-1017 ) because I called the company and that is the only one they “recommended”. Next oil change I’ll use the longer one. Appreciate the info Man.
Let me ask since you seem to be the viscosity go to guy. What fluids are you using for your front - Rear diff , transfer case & trans ? Getting ready to do those next.
Went with GM and ACDelco fluids right after I bought the truck. Took to Cadillac and let them do fluid exchange last time for the transmission. This time around I could not locate ACDelco front differential fluid so I used Lucas 80W90 10043 in the front. Yours is spec'd for 75W90 up front, full synthetic. I think we'll run the Lucas 10047 in the rear if I do not have enough left in the garage. The one gallon bottles are all nearly the same price between Lucas, Red-Line and ACDelco, about $50. Running ACDelco Dexron VI full synthetic in the transmission and transfer case. Looking to buy 6 gallon box (10-9167) from RockAuto soon.
Nap73
Nap73
What about Amsoil SEVERE GEAR 75W-90 ?
PA-WOODCHUCK
Synthetic, along with OEM filter or higher quality such as mobil1 oil filter. I have a performance boat with 8.1l(425HP) and only use Mobil-1 and there filter and engine is always under load running in the 3-5K RPM range. Nuf said!!! Can't go wrong with full synthetic which is what I'm been using in all my toys for the past 15+ yrs. My Yukon is going mobil-1 once the factory free oil changes are over.
bfourman
Indiana
Full synthetic Supertech 10w30 and a K&N HP2011 filter. 235k on my 09 2500 6.0.
5k oil change intervals and I never have more than a couple ounces in my catch can.
HiHoeSilver
Away!
Chicago
Got me even more curious now, James.
1. Where did the 10-12 micron rating come from? Is that nominal? What's the efficiency? I can't find it anywhere.
2. I see on the Mobil1 website, 99% at 30 microns.
3. I know from prior research that the ACDelco pf44 that turned pf46e was a change from 30 down to a 10 micron rating (in an email I found from Delco) yet even their top dog UltraGuard shows 98% at 25-30 microns on their site.
Here's why: Nominal ratings vs actual efficiency.
I can (and do) buy lots of filters for different industrial applications. A filter rated at 10 microns nominal (which is my bet for the K&N, as nominal ratings are pretty common practice) may only be 50% efficient at that resolution. Given the 98&99% efficiency boasted on the Delco and Mobil websites, their nominal ratings may very well be the same or better than the mysterious K&N # (assuming the 10-12 number is nominal). I'm betting all three have almost identical "premium" synthetic blend media.
Would love to see some actual spec sheets.
Just an example table from one of my suppliers:
I'm sure it would be fine, Amsoil and Red-Line use Group IV based oils, they are the best from what I've red, Royal Purple too.
I don't remember Nate, it took many hours of searching and only bits and pieces were gleaned, could very well be they were just advertising the best and they run the same with 30 micron particles. I did and do see a difference in oil pressure and the flow ratings are much more for the K&N. Much more filter media in the K&N cans, seen youtube videos with both cut open.
HiHoeSilver
Away!
Chicago
I'm going to have to do some digging. You've got me looking at different oil and now different filters! You're rocking my boat, James! Lol
Nap73
Nap73
Why 10w30 ?
Nap73
Nap73
Why 10w30 ?
What are you running in your diffs , transfer case & trans ?
SnowDrifter
Sasquatch Country
Pressure is read post-filter.
If you consider the filter as a restriction in the loop, and that the total pressure is a sum of each point of pressure drop:
Suppose theoretically that you have 50psi off your pump. 5psi drop from the filter would net 45 psi usable pressure after the filter - what your sending unit sees.
HiHoeSilver
Away!
Chicago
That's my point. The "better" or lower resolution filter should yield higher resistance and therefore a lower pressure reading at the gauge, no?
bfourman
Indiana
Why 10w30 ?
This last time of 10w30 was an experiment to see if it resulted in better cold oil pressure. It didn't, still 40-45 lbs cold and 25ish hot idle.
Front diff and t'case are unknown, both levels were good and fluid have been clean since I bought it a year ago. Likely will change over the winter. 80w90 for the front and AC Delco autotrak fluid for the t'case.
Trans is same story but it will be changed with a filter this winter with Service Pro Global Full Synthetic ATF.
Rear diff is generic dino 80w90 changed when I did the rear wheel seal this spring. 14b specs don't call for anything special.
I'm solidly in the "oil is oil" camp when it comes to fluids. Brand doesn't matter, they all meet the same spec. I have used Supertech or Harvest King (Rural King house brand) oils in all my vehicles for years with no ill effects. Make your own decisions and don't flame those that don't agree. Unless they use Fram filters lol.
/soapbox
bfourman
Indiana
Additionally this Suburban is the only vehicle I have ever used premium filters on. Historically I run Supertech filters because they use a metal "cage" vs most others; AC Delco included, that use plastic. Folks on here suggested the K&N so I gave it a shot. Results showed a slight hot idle increase in oil pressure so I have continued to use the long 2011 filter. The nut on the bottom is a contributing factor also.
Foggy
KS
I've been using the Wix 57045 XP for a while now.. The 57045 too.
IT's the same threads/etc as the 57060 but longer. So it's holds a little more oil and has a little more filter area.
avalonandl
Troy, MICH & Naples, FL
Wix Filters are simply the best. Fram, the worst.
Mobil 1 and Pennzoil Platinum have the highest shear numbers in oil tests.
The quality of oils we have are so much better than 20 years ago. Even the Wally world Supertech Synthetic is great protection.
I disagree Roger, Mobil was a better oil ten years ago, it was a Group IV based oil until then. What ASTM numbers are you referencing for shear numbers?
As for oil filters, Wix flows about the same as Mobil's EP filters which is about 10-12 gallons per minute versus 16 GPM for K&N. Wix advertises a 21 micron rating, K&N, about half that. I noticed a definite drop in oil pressure with the M1 EP filters versus the K&N. Other than that, I reckon it's rivet counting and not such a big deal.
Edit: Ok, jogged my memory about those HTHS numbers and ASTM numbers. Unfortunately, those numbers have eluded me for Shell's Rotella Gas Truck and the ACDelco oil. If anyone finds them, please post!
enigmaspeed27
