The Khan - 2005 Yukon Slt buiild
Fosscore
Digging the build thread. Some nice work and good parts scores as well. And the FFDP version is pretty solid IMHO!
SteveB
SteveB
Thanks Fosscore. It helps I work in a bodyshop and we scrape and wrote off vehicles for parts. There's still few mods I want to do yet. Headlights ,led lighting , lower it a bit , dual exhaust , 20'' rims , dual batteries. Trying do it on a budget.
SteveB
SteveB
So my blend door actuator died. So I pulled it off and turned the blend door by hand. Then today I was getting cold air from the front on the driver's side , so I did a relearn on it and it works again. The video I used.
Sam Harris
Score!
SteveB
SteveB
Catch can installed.
SteveB
SteveB
Looks good! I bought @Fosscore ’s catch can he had for sale. Should get delivered tomorrow. Any advice on install or a write up on the install? I’ve never done one so this is new territory!
Stupid easy to install. The worst was trying to find a spot that I was happy with for draining and routing the hoses. I used about 6ft of 3/8 fuel line for the hoses. Hook up the in port on the can to the pcv valve located at the back of the diver's side valve cover , the out port goes to the intake where the old hose was. I tried to run my hoses where the fuel line connects to the fuel rail on the intake. My reason for that is the covers fit with the fuel line there....lol. I started routing the out hose first since I figured that would be the worst line to do and it's also the longest for how I mounted my can.
SteveB
SteveB
Got the rear dvd set-up finally today no more big holes in my headliner. From my understanding cause of aftermarket head unit , I can't use.
Bear77
South FL
I say differently. I installed an aftermarket head unit and I’m still able to use the factory rear entertainment system.
SteveB
SteveB
Interested on how you did that.
SteveB
SteveB
Pretty sure mine isn't a dual zone one.
SteveB
SteveB
Haven't been on here in awhile. Not a lot to update. Have to replace the tranny if gave up the ghost a couple of weeks ago. Came across a Denali in our wrecking yard grabbed the cluster (needs rebuilt) , dash bezel , console. We also have pretty trashed SS truck in the yard so I gabbed that cluster too. Really liking the white face gauges but not real keen on the needles , might swap the needles off the Denali gauges. Hoping to have a tranny swapped in by the end of the weekend. Will post a pic of the dash and console when I finish the console swap.
adventurenali92
Big Bear Lake, ca
I have the white gauge face on my escalade cluster. With blue needles and the silver needle gases it looks really good.
How many miles on that transmission?
Bob LaFord
