2017 Denali After 1.5” rear lift - Rear end hits bumps HARD
AZ Rat
Arizona
2017 Yukon Denai 4x4
I just installed the SuspensionMaxx 2.5” Front / 1.5” Rear Lift. The rear end hits extremely hard over speed bumps. MUCH more than prior to the lift. Anyone else experience this as well?
Big Mama
Virginia
Did it come with shock relocation brackets or bigger bump stops?
AZ Rat
AZ Rat
Arizona
Just had the rear shock relocators installed. Initial drive (only ~2 miles) and 2 speed bumps later and it handled SO MUCH BETTER!
I will post more updates as I can.
Big Mama
Virginia
That’s great thanks for following up so the next guy will know.
bamachem
Same experience here. Shock extenders made a HUGE difference in the rear.
kiwi
Mother Яussia
Guys, what is the part number or exact name of this relocation bracket? Did 1" rear lift and experience the same problem.
Big Mama
Virginia
There are several different brands but yes shock relocation brackets. His lift was 1.5” but same deal. By lifting you stretched the shock the bracket puts it back where it was.
spate47
San Angelo, TX
Has anyone run 5100s in the rear instead of a spacer? Or would it be better of running a .75-1" spacer with bilsteins at stock height?
AZ Rat
AZ Rat
Arizona
Did you wind up purchasing the 2" relocation bracket even though you lifted the rear 1"?
Hi,
I did the Full SuspensionMaxx 2.5” Front, 1.5” Rear with the 2” Shock Extension.
Added 285/60/20 BFG All Terrain KO2 with OEM Denali rims.
I rub a little bit @ full turn.
CKendrick
