Sam Harris
Today I washed it and applied a brand new product from Chemical Guys called Hydroslick Ceramic Coating Hyperwax. It’s supposed to be a ceramic coating that is in gel form and just wipes on and then buffs off. It has no wax. It has no Carnuba. It’s supposed to be a whole new category. I can say one thing- it’s a PIA to apply since it’s pretty much invisible as it goes on. It leaves no haze so you can’t tell if you missed a spot when its time to buff it off. Supposedly it lasts 6 months to a year. View attachment 231244View attachment 231245
I guess if it actually lasts as long as they say, a PITA application is worth it..
Well...I decided to do the bumper mod at 1 in the afternoon, thinking it looked like 3 hours tops. I should have known that any time I take apart something on my truck that hasn’t been touched in 17 years it doesn’t go fast. There’s a plate with a nut welded to it on each side that sit in a pocket in the fiberglass part of the bumper that’s behind the skin. These were rusted so when I removed the bolts, even with penetrating spray, the force twisted the plates which broke the pop rivets so they fell inside which meant the skin had to come off. By the time I went to Ace , bought extra long pop rivers and fixed them, I decided to put it all back together since 3 hours had already passed. There was no way it was getting done today since there was welding involved. It’s supposed to rain for a couple days, but I’ll get to it after that. Dammit.
9DA3B132-1D93-4F96-B17E-D7857AA291C0.jpeg E16D8E64-605B-441A-BF6B-3E6553C904DC.jpeg C8E50220-CAE4-4D93-B7D7-5B5CD3B5CE10.jpeg
HiHoeSilver
Away!
Chicago
View attachment 231376 View attachment 231377 View attachment 231378
Sucks. One of those "nut plates" came off of mine, too, but it was one of the horizontal ones near the middle. Grrr.
ivin74
05 NBS Nali
Htown, Texas
Damn you don't **** around, you tore that front end down quick. Keep us posted
First, I'd like to say thanks to @ivin74 for the motivation to get this done. Now here's my before and after pics for comparison. I can't believe I waited this long to do this, it's bothered me since I bought the truck.
edit: yes I still have to reinstall my lower valance. Maybe it will clear curbs a bit better now. I have already removed an inch off the bottom but it still hits on some when I park. This gives it about another 3/4".
I did find a couple ways to make this easier, at least they worked out for me. I spent 2 hours total to complete this today, and with no welding. I had the advantage of looking at Ivin's thread and thinking on it overnight. I thought, why not attempt to just bend the lower brackets up and bending them flat, then re-drilling the holes to make them line up instead of cutting them off and welding them. Also, for the outer brackets, instead of notching them, I knew from working on the bumpers on my NNBS Silvy and making it work, there were adjustments that can be made. I used a 3-lb sledge on the lower brackets and bent them up and then pretty much taking the bend out of them and making them flatter which allowed the bumper to be raised without hitting them. I used 5 washers like Ivin, wrapped in electrical tape so I could pull the bumper on and off a few times without them falling apart while I re-drilled holes or made adjustments. I didn't take many pics, I was in a bit of a hurry since it looked like rain was coming.
bolts
As for the outer brackets inside the fenders, I just loosened their mounting bolts and was able to lift both of them almost an inch. I did have to enlarge the holes a bit to one side after that but that was it. I used an air die grinder to enlarge holes which made quick work. I pulled the bumper about 6 times to mark holes and enlarge them or adjust things but it turned out to be pretty easy. As for the grill, I didn't need to do anything to it. And like Ivin said, there was just enough room under the grill to get a screwdriver in to turn the plastic clip that holds it in.
ivin74
05 NBS Nali
Htown, Texas
View attachment 231417 View attachment 231418 View attachment 231419 View attachment 231421 View attachment 231422 As for the outer brackets inside the fenders, I just loosened their mounting bolts and was able to lift both of them almost an inch. I did have to enlarge the holes a bit to one side after that but that was it. I used an air die grinder to enlarge holes which made quick work. I pulled the bumper about 6 times to mark holes and enlarge them or adjust things but it turned out to be pretty easy. As for the grill, I didn't need to do anything to it. And like Ivin said, there was just enough room under the grill to get a screwdriver in to turn the plastic clip that holds it in.
The beast looks Beast now!
It didn't even think about bending the clips and redrilling, great idea, it saves time and money.
Oh dear God... tell me that's not what I think it is...
:eek:
Say it isn't so... lol
:nono:
Sorry Mark... gotta break em once in a while... don't get the chance very often with your caliber of work.
Busted. I do NOT like this. I was going to convert to AN fittings on the trans lines but haven't gotten to it. Stupid Tru Cool provides single screw clamps to use on their lines so at least I doubled them. I hang my head.:oops:
NathanJax
Vacation Nathan
Jax, Fl
Looks good. I need to do this to my truck's bumper...
edit: yes I still have to reinstall my lower valance. Maybe it will clear curbs a bit better now. I have already removed an inch off the bottom but it still hits on some when I park. This gives it about another 3/4".View attachment 231411 View attachment 231412
*SIGH----As usual.....looks great Mark :oops:
TheAutumnWind
Looks much better especially for 2 hrs work!
6point2lovelifers
