ABS & Service Stabilitrak
jrobie79
2011 Escalade: ABS & Traction Control Lights are on & Service Stabilitrak message on DIC.
background: I was working in Florida for several months and left my Escalade parked at home while I was down there, when I came back the battery was dead, so I jumped it, and since then my ABS & traction control lights are lit on my instrument cluster and I get the "Service Stabilitrak" message on the DIC. I've been poking around a bit and came across some possible reasons being that the dead battery causes the electronics to go haywire, not sure how, but that's what I've read, which could be the reason the lights are on. I checked all the battery cables and tightened them down, but the lights are still there.
Does anyone have any suggestions on what to test and how to diagnose?
have you tried disconnecting the battery again and while it is disconnected put the key in and turn it to start a couple times, turn the headlight switch on/off a few times, hit the brake pedal a few times then hook the battery back up, this will kill any static power that could have a caused a problem. if not then you might need to get it scanned with a tech2 and see what it is telling you a regular code reader wont work for stabiltrac errors unless you get lucky and find it to be a abs wheel sensor (reader must be capable of reading abs codes).
ivin74
05 NBS Nali
Htown, Texas
Get the speed sensors checked out, the's one on each wheel. The fronts are on the hubs and the rears are on the rear end. Someone with a tech 2 can read the abs codes.
J
jrobie79
I've been driving it 3/4 days a week for about a month since it started, I'm guessing this wouldn't help much now right?
Drive the truck for a few hours or put the battery on a slow charge, jumping it is not enough to make the system completely happy. Then clear all the codes and take it from there. It's possible then that the battery will need replacing.
J
jrobie79
Been driving it for a month now, I figured it would just go away as it was the dead battery, but that likely isn't going to happen, so now I need to fix it
the procedure I explained will take 5 minutes of your time, I figure it's worth a try, these trucks are power "finicky" if I disconnect my battery I have to follow the procedure or it wont even start, the security module in my truck doesn't like the battery being disconnected, it will pop up once with the security error on the DIC and then it wont even respond, dead to the world unless I do what I explained above. If the battery power is low or the cables or connection is bad they can do all kinds of weird stuff, I can tell when my battery gets even slightly low because the rear hatch wont latch it will look like it is but if you just barely bump it then it finishes locking
J
jrobie79
I'll give it a shot after work today and report back
J
jrobie79
No change, looks like I'm in the market for a tech 2
The_Burban
Why not replace the battery? Or at the very least get it tested?
Seems like a voltage issue more than anything else.
They're not three grand anymore, you can get one off ebay or from China/Hong Kong in about a week.
Make sure it has the Candi module and 33.004 software and it will come with a bunch of adapters and test stuff and maybe the old software for computers. But for the purpose of diagnosing your problem you won't need the latter. Average is about $350 delivered last time I looked.
Mazer16
