Windshield washer Fluid not spraying
Michigan
Few questions
On an 04 tahoe does the front and rear washer fluid share the same pump?
Rear washer fluid is spraying the back window fine
I was triggering the front windshield and nothing coming out. I noticed a puddle of washer fluid underneath the front bumper on drivers side. I noticed this after trying to spray the front and the rear.
Now that I think about it I haven’t tried using the front or rear washer fluid since before I had my truck in the shop for a water pump replacement. I don’t know if they unhooked a hose or moved something out the way when they replaced the water pump
Where do I start? When I activate the front washer fluid switch I do not hear any fluid trying to be sprayed but apparently I think it’s just spraying underneath the car
ivin74
05 NBS Nali
Htown, Texas
The front windshield washer has its on pump. You need to remove the driver front tire, fender liner, battery and battery tray to inspect or replace. Its a shit load of work to change out a 20 dollar part
treehan77
TYF Fiend
Crestview, FL
Yep the cases for the washer pump cracks very often. Try that first, local parts store usually stocks them for 20 bucks or so. There’s 2, might wanna do both while you have it apart
MrBalll
West Texas
Also check your lines. My front line cracked and was spraying fluid all over the engine bay. It runs along the drivers side fender on top.
