1badc4
- Joined
- Jun 17, 2019
- Posts
- 282
- Reaction score
- 216
Thanks. Learning as I go lolNice job.
That box barely has any volume as it is, good thing you didn’t put the amp inside it if that’s what you were trying to do or it would be even less. Too bad MTX quit making the Thunderform enclosure, it has enough for a 10”.Cut out, I ended up scrapping that Idea. Amp didn't fit in box the way I liked. Gonna just put the tube back together. Making slow progress. View attachment 228777 View attachment 228778 View attachment 228779
Yeah I have one too but with a JL sub.
It should sound okay with tube just mounted on floor in rear. Was hoping to avoid but it will be quick disconnect so nit bad.That box barely has any volume as it is, good thing you didn’t put the amp inside it if that’s what you were trying to do or it would be even less. Too bad MTX quit making the Thunderform enclosure, it has enough for a 10”.
That sucker is sharp! I had to take mine out too.We don't need no stinking bracketView attachment 229311 View attachment 229312 View attachment 229313
Gotta let us know how the fit is. Use your metal clips from the original bezel tho, I heard the metra clips suk.Well I can finally wrap this radio install up. Just received my metra dash kit. Think I may hydro dip it. View attachment 230312 View attachment 230313 View attachment 230314
Probably do it tomorrow or Thursday. I'll post results. Trying to manage time. Also have to finish the job I started on my Corvette. Only had it out once since spring. And have a car show the 21st and race event in November.Gotta let us know how the fit is. Use your metal clips from the original bezel tho, I heard the metra clips suk.
No rear wiper switch?Installed the new Metra dash bezel today. very happy with ease of installation and fitment. couple notes, definitely good advise using OEM clips. on the rear there were some pins that the oem piece had rubber caps on that the Metra piece did not, I assume anti rattle, they were easy enough to transfer over. head unit brackets worked great. hardest part of the job was Removing OEM clips from stock bezel. not too bad just that was the hardest part. I am so happy I went this route over modding mine or the 03+ mod which looked like a pia. overall extremely happy. in the future I will hydro dip for coolness. although in my gray interior the matt black could pass for oem. IMOView attachment 230502 View attachment 230503 View attachment 230504 View attachment 230505 View attachment 230506
Barn doorsNo rear wiper switch?
Ah yes, I forgot.Barn doors
