Snapped manifold bolt
Livebai8
Houston, Texas
Well...looks like my torque wrench failed me on my first bolt tightening...snapped the bolt at 44 foot lbs...now I have to take it all back off to get that bolt out...FML...
Sent from my SM-N920T using Tapatalk
Th
Yeah that’s a lot of torque for either an exhaust manifold OR intake manifold bolt. Where did you get the torque specs?
Livebai8
Livebai8
Houston, Texas
I just entered torque spec for 5.3l engine...the videos I've watched also said the same thing...two passes 1st at 44lbs and second at 89lbs. This is the page I printed.cd231361349d028832106935ea2a125d.jpg
Livebai8
Livebai8
Houston, Texas
Would these apply to the intake manifold? This says exhaust manifold.
SnowDrifter
Washington. The desert side not the Starbucks side
The page you printed is for the intake manifold. I posted specs for both exhaust and intake manifold as I wasn't sure which one you were referencing in your original post
The torque specs listed would be INCH pounds, not foot pounds. 44 inch pounds = 3.7 foot pounds
Oops. Not the first time I’ve seen this. If you torqued your intake manifold bolts to 44 ft lbs you might have wrecked it. It’s plastic and not meant for that kind of force.
montanaboy65
