Dual OEM USB to replace 12V in dash
bdhmsg
Has anyone installed dual OEM USB connectors in the dash? I’m having a problem finding a mini USB splitter to connect both to the factory radio(2012 Yukon w/nav). I can find micro USB splitters all day.
bdhmsg
bdhmsg
bdhmsg
bdhmsg
Yea’, I may have to go the China route. I was just trying to keep from waiting over a month on it.
you could also check cable matters & mono price they both sell all kinds of adapters
Check Newegg.com for what you're looking for. If they don't have it, it doesn't exist.
I put those in soon after buying our truck and removed them for more powerful flush mount ones with 2 2.5A ports in each.
bdhmsg
bdhmsg
Did you have problems with them charging or playing music?
Not at all for charging, my truck is older and did not have ability to play music through them, that was added in 2010. When we're all in the truck, there's just too much junk to keep charged up! So the dual adapters that charge at 2.4A and 2.5A for both ports in the adapter works better for us. Bought a cell phone holder that fits in the cupholder that has cigar lighter sockets and USB ports too and it plugs into one of the truck's cigar lighters now on the dash. Plus I have a dash cam that is not permanently wired either.
91RS
GA
I don't think the radio can support more than one device at a time since that's all it was designed to handle. Plus, the stock radio doesn't put out much amperage to charge even one device while that device is being used. I was using my phone to navigate and play music on the way home when we bought my wife's Yukon and the battery was still dying. The newer trucks basically have USB hubs in the receptacles but they are designed to handle multiple devices and also have a separate 12v input to provide enough power to charge more than one device at a time.
bdhmsg
bdhmsg
When you had the oem usbs, what did you use to connect them to the radio?
bdhmsg
bdhmsg
Interesting. I’ll look deeper into it.
St. Louis
I can't get mine to recognize or play music from my phone when plugged in, unless I plug into the AUX.
Now it will see a usb stick with music files on it and play them
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
Drewphil
