T-Case Dissembled
Dan2002
my 02 denali had a knock when pressing ******* the accelerator, its been about 2 years. it didn't bother me much. until this week it started to make a sound when barely taking off.
checked my transfer case and saw that it had about half quart of fluid. when i drained it.
so i decided to take it down and check inside it. first problem i came across is that it had the small driveshaft that goes from transfer case to the front differential, would not come off at all. i noticed it didnt have a boot that usually covers it from the weather and stuff.
I ended up cutting the driveshaft to be able to take out the transfer case. i got a really nice one with boot at my local junk yard.
after splitting the transfer case. i pulled out the magnet and did not found any significant metal pieces.
only very fine (paste like) metal. all bearings look in very good shape.
i do think that the chain seems to be too loose. i dont know if that is how is supposed to be,
also i saw that the clip holding a bearing inside has eaten trough the case and made a small hole by the speed sensor.
can anyone with experience give me a few tips.?
Erickk120
Looks like a lot of chain play, Although it is apart so it could be the shafts being close to each other. Planning to rebuild it, or just slapping a new chain, pump cover and put it back in? If the noise was kind of constant, or there til the chain loaded then it could possibly be a chain issue, have seen it before.
D
Dan2002
Was thinking of only fixing the knock it had and putting it back together. All bearings are in excellent condition.
The knock it came to be Everytime I put in load on the engine. It would only knock about 3 to 4 times and stop.
JonnyTahoe
Minneapolis
Just watched a few I-case video's as I am doing a removal as well. Your chain is not suppose to have that amount of play.
curbud
