Cucv
Pdx
Painted my grill on my Escalade. It looked horrible, now its ok.
Pilot
Bloomfield, NJ * Lewes Beach, DE * Buenos Aires
Upgraded (IMO) my dash to two-tone black and tan this weekend by installing a Coverlay dash cover. Also replaced the clips on my Metra double-din dash bezel from the ****** aftermarket ones it comes with to new OEM clips I ordered. It fits way better now–much more tight and sturdy. I walked through both upgrades in a video:
SnowDrifter
Sasquatch Country
Going to see if my injectors are a bit grimey or if injector cleaner doesn't work. Took a before measurement. 40mi freeway, 60mph with like 2 slowdown-speed ups. Guess we'll see what happens
No change. Nothing that I can't attribute to random variance anyway. Misfire counts, long term fuel trims, and idle feel remain unchanged. So my takeaways are: either my injectors are fine, or they aren't and the tank added fuel injector cleaner is ineffective. Couldn't say without pulling injectors and measuring flow / pattern and I'm not going to do that
No change:cool::cool::cool::cool:. Nothing that I can't attribute to random variance anyway. Misfire counts, long term fuel trims, and idle feel remain unchanged. So my takeaways are: either my injectors are fine, or they aren't and the tank added fuel injector cleaner is ineffective. Couldn't say without pulling injectors and measuring flow / pattern and I'm not going to do that
Something wrong with that mileage? It’s twice what I get :cool:
Woodblocker55
Now can you replace the 2015 keey flob with my old 2006 keey flob ? [emoji849][emoji15]With factory remote start.. because my originals look just like yours.
Let's say they have some serious miles on them lol.
I know I can open doors and start with app on cellphone using my obdlink adapter.
Sent from my LGL84VL using Tapatalk
Yes the remote start also works on the one for my 08 Silverado. Boost Auto Parts, https://boostautoparts.com/products/fob
ivin74
05 NBS Nali
Htown, Texas
Put a LOT of time into the Tahoe this weekend. Permanently installed a battery maintainer with a plug mounted on the bumper, painted the passenger airbag cover, installed a Coverlay dash cover, installed a custom switch panel where the cassette player used to be.. This is a quick write-up on the battery maintainer.
So I've been having a TON of trouble with my Tahoe battery. I have a bunch of equipment that draws on the battery at all times and I don't drive it on a daily basis. In fact, I go out of town at least once a month. So three batteries have died on me, including my hella expensive XS Power D3400, which not only died, but is damaged an unchargable. :(
My plan is to eventually install a second battery for accessories, isolated from the starter battery (already bought the mounting tray), but for now, I made my owner extension cable:
  1. 3 wire power cable https://www.amazon.com/gp/product/B07F5YWC7B/ref=ppx_yo_dt_b_asin_title_o00_s01?ie=UTF8&psc=1
  2. Male 3 prong weather resistant outlet https://www.amazon.com/gp/product/B074T57WS6/ref=ppx_yo_dt_b_asin_title_o00_s02?ie=UTF8&psc=1
  3. Female 3 prong weather resistant outlet https://www.amazon.com/gp/product/B07SLM8LT5/ref=ppx_yo_dt_b_asin_title_o00_s02?ie=UTF8&psc=1
I have an aftermarket Hammerhead flush-mount rear bumper that already had a 1.75" hole for access to the key cylinder for the stock spare tire release. The outlet fit in there perfectly! I mounted my battery maintainer directly on top of my battery and ran the cable to the rear bumper. Here's a video of the process:
And here are some photos:
I'l try to cut together a video(s) of the dash cover and switch panel later today.
Great mod, that's my next mod. My SUV is not a daily either and I'm having the same battery issue you have.
SnowDrifter
Sasquatch Country
What oil and filter do you run?what's your oci?
Mobil 1 0w30 esp
Either amsoil eao64 or Fram ph3675
Was 3.5k
Shortened to 2.5k
My poor rig gets the hell short tripped out of it especially in winter where I loathe driving anywhere
Switching to Castrol euro 0w40 cause the local Napa stopped with their specials. Used to be able to get it for dirt cheap but meh. We'll see how the Castrol does. It's Thin for a 40 but my only worry is it might be a wee thick for my application. 13.2cst at 100c if I recall
TejasPitt
