2003 Yukon Problem
N
Nyjetfan21
I finally had the chance to scan the codes and I got the same two codes P134 and P300. I already installed AC Delco platinum plugs and wires and also changed the O2 Sensor bank 1 sensor 1. I never cleared the code after I changed the plugs and wires. Here are the picture of the scan codes that I got.
N
Nyjetfan21
I finally had the chance to scan the codes and I got the same two codes P134 and P300. I already installed AC Delco platinum plugs and wires and also changed the O2 Sensor bank 1 sensor 1. I never cleared the code after I changed the plugs and wires. Here are the picture of the scan codes that I got. I also got a code P1133 now. I did clear all the codes this morning as well. Any help would be great thank you
EDADCF97-CE5E-4264-8CB3-1C6BAE97434A.jpeg 6D822167-A25B-4EDE-855C-49F3932EDECA.jpeg 9AC80DE4-3978-4594-B142-DA07B4E5995C.jpeg
HiHoeSilver
Away!
Chicago
You never cleared the code so the light never went away? Start by clearing it and see if it comes back. You may have already fixed it.
N
Nyjetfan21
OK thank you I’ll let you guys know tomorrow or Thursday if the engine light comes back on after driving it . That should hopefully be enough driving for the light to pop back on, but hopefully it dont
SnowDrifter
Washington. The desert side not the Starbucks side
Ohhh I misunderstood. Thought you were still getting codes after doing the work.
Yeah clear codes and just drive it. You can scan again to see if there are any pending codes - items that the vehicle is picking up on but hasn't yet met the threshold to throw a MIL
N
Nyjetfan21
E55FB398-9A19-4BEA-A430-E8125BB853A0.jpegE55FB398-9A19-4BEA-A430-E8125BB853A0.jpeg E55FB398-9A19-4BEA-A430-E8125BB853A0.jpeg A9724520-AD00-486D-8616-E76B688E5CFA.jpeg A9724520-AD00-486D-8616-E76B688E5CFA.jpeg Its been 3 days since I cleared the engine light and it popped back on last night. I rescanned it today and I got only 2 codes now instead of 3 codes. The codes I have are the same as above. Here is A pic of codes. I stated in a previous post I already changed the O2 sensor. I did buy a really cheap one online for 13.00. Any suggestions would be great. Ty
ridnclean18
