TheAutumnWind
I want to do this. Is it plug n play? Do I need larger than stock wheels? (I’m sure) can you just buy off the shelf calipers, and bolt them on?
Wheels 17" or bigger are fine iirc. Calipers with the brackets and pads and rotors that match. They bolt right up. They fill up a 20" wheel much better than stock
Edit here's mine excuse the disgustingly dirty wheel.
20190703_182014.jpg 20190703_182009.jpg 207944-3187413fe3e47b966dbdcd8436ed8c8f.jpg
TheAutumnWind
This is my rf rotor. Pad only making half contact. Never seen that before
Well that isn't right.
Ive seen worse lol. Buddy of mine installed pads backwards. Ive seen pads worn down to the rivets/backing plates...crazy sobs are on the road with us...scary af.
Sam Harris
dszx13
These are getting close to the rivets. It’s been needing tlc for awhile now. I work on everyone else’s and put mine off until I absolutely have too. But half contact is a first for me
I’ve never seen that either. Are the rotors warped?
dszx13
Probably. But it would have high and low spots all over the contact area. Not consistent like that. I’m gonna pull it apart this weekend.
TheAutumnWind
Thanks! Eventually I’ll upgrade the wheels. Until then, I’ll be stuck with NBS..
Oh you have 16s? Bummer. Lots of inexpensive wheels for these trucks available luckily. I bought some 20" welds for my old denali for $200 on craigslist.
Those are my stock 20's on the caddy tho.
TheAutumnWind
Pad mustve partially broken off the backing plate or something.
Scottydoggs
NJ
caliper might be bent. olny time ive seen such uneven wear.
1badc4
How about this for a simple thread. I know a lot of us do simple stuff to our trucks everyday and we don't make a new thread for everything we do. So if you did something neat, simple, or just want to brag about a new cool piece you threw on your ride post it up. I figure this thread will also bring inspiration to others as well.
I'll start.....
Today I did some spring cleaning to the my '01 Tahoe. I washed it and cleaned out the inside. I also ordered some new JL audio speakers for the doors and front and rear Weathertech floor mats. I also put some sound deadening material in the doors.
Jack your post count up, and post away.
-Ben
Prepping Tahoe for motor swap from Z71 Suburban. starting Saturday. Goal is pull both motors this weekend, during next week pressure wash Tahoe engine bay and re gasket Suburban motor then install in Tahoe next weekend.
SnowDrifter
Sasquatch Country
Pretty much plug and play on stock 17s.
Of note, if you're like me and hate clip on weights, use the thin sticky weights. Not the thick(heavy) ones. I have maybe 2mm of clearance between my wheel weights and caliper. They rub the slightest bit on hard turns.
HiHoeSilver
Away!
Chicago
Good point. I never even thought of weights. I know it's pretty tight with 17s.
dizhai
