SnowDrifter
Brackets and hardware were included. Don't remember if it came w/ cooler fittings or not.Let me know. I plan on ordering one this week or next. What’s in the pt kit?
It's. Brain dead easy. Basically remove the front cover, disconnect stock cooler lines, remove temp sensor, remove cooler. Grab a pipe cutter, cut the passenger side line, rotate 180 degrees, then install the included compression fitting. Install connectors to the cooler, mount brackets, cooler, temp sensor, connect lines, top up fluid, reinstall front cover, and you're set. Took me 30 or 45 mins sitting in the O'Reillys parking lot
