SnowDrifter
Sasquatch Country
Let me know. I plan on ordering one this week or next. What’s in the pt kit?
Brackets and hardware were included. Don't remember if it came w/ cooler fittings or not.
It's. Brain dead easy. Basically remove the front cover, disconnect stock cooler lines, remove temp sensor, remove cooler. Grab a pipe cutter, cut the passenger side line, rotate 180 degrees, then install the included compression fitting. Install connectors to the cooler, mount brackets, cooler, temp sensor, connect lines, top up fluid, reinstall front cover, and you're set. Took me 30 or 45 mins sitting in the O'Reillys parking lot
TheAutumnWind
Yeah the PT.net kit seems real easy.
SnowDrifter
Sasquatch Country
Very nice. Wheres the how to?
Edit: ooooooops wrong answer
Will post when I get home
Edit again: here ya go
relays are wired weird. Fan relay 1 and 2 ground through pin 86, fan relay 3 grounds through pin 85
TheAutumnWind
Stock size. By stuck I mean seize up
Grease the slide pins. That's normal procedure in a brake job.
Shoot if you're going so far as to replace pads and rotors might as well spend a few bucks more and upgrade to nnbs front calipers and rotors and pads.
Sam Harris
I want to do this. Is it plug n play? Do I need larger than stock wheels? (I’m sure) can you just buy off the shelf calipers, and bolt them on?
dszx13
I planned on doing the nnbs rotors. I still have those drilled and slotted ones from my Sierra. I don’t want to buy any more than I have to since I still need to replace the whole front end. On top of the stock trans cooler not cooling so I have to address that also. Only have so much spare money for parts[emoji2371] lol
TheAutumnWind
Ordered acdelco pro upper arms and got some made in china. Are these still good arms? They do have the blue boot on the ball joint atleast...so I guess they aren't the "advantage " junk
Escalade2007
